Mills Landing
CNC Mills Designed for People Who Make Things
Easier to buy, easier to learn, easier to use.
Big or small – own your shop floor like a boss. Build your mill into any space.
Tormach’s CNC mills are designed to provide industrial capabilities and fit into any space. They have the ability to maximize your profitability because all three have enough torque to cut stainless steel without crowding out other machines.
Remember the Little Engine that Could? This is what it looks like.
With the ability to run any G-Code and cut any material the big guys can, our mills come preinstalled with optimism and courage.
— Engineered and supported in the usa
Mill Comparison Guide
1100M
X-Axis: 18 Inches
Y-Axis: 11 Inches
Z-Axis: 16-1/4 inches
770M
X-Axis: 14 Inches
Y-Axis: 7-1/2 Inches
Z-Axis: 13-1/4 inches
PCNC 440
X-Axis: 10 Inches
Y-Axis: 6-1/4 Inches
Z-Axis: 10 inches
Spindle:
1100M
Spindle Power: 2 hp
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Tension/Compression, Auto-Reversing, Thread Mill&lt
770M
Spindle Power: 1-1/2 hp
Maximum Speed: 10,000 RPM
Spindle Taper: R8
PCNC 440
Spindle Power: 3/4 hp
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate:
1100M
X- and Y-Axis: 110 IPM
Z-Axis: 90 IPM
770M
X- and Y-Axis: 135 IPM
Z-Axis: 110 IPM
PCNC 440
Z-Axis: 110 IPM
Power:
1100M
Power Required: 230 Vac, 20A breaker
770M
Power Required: 115 Vac, 15A breaker
PCNC 440
Machine Dimensions:
1100M
Table Size: 34 inches × 9-1/2 inches
Table Slots: 5/8 inches (three slots)
Spindle Note to Table Max Clearance: 17 inches
Spindle Centerline to Machine Column: 11 inches
Typical System Footprint: 69 inches × 56-1/2 inches
Overall System Height: 96 inches
Typical System Weight: 1580 lb
770M
Table Size: 26 inches × 8 inches
Spindle Note to Table Max Clearance: 13-1/4 inches
Spindle Centerline to Machine Column: 8.6 inches
Typical System Footprint: 56 inches × 48-1/2 inches
Overall System Height: 88 inches
Typical System Weight: 908 lb
PCNC 440
Table Size: 18 inches × 6.3 inches
Table Slots: 3/8 inches (three slots)
Spindle Note to Table Max Clearance: 11 inches
Spindle Centerline to Machine Column: 6-1/2 inches
Typical System Footprint: 42 inches × 36 inches
Overall System Height: 72 inches
Typical System Weight: 600 lb
Controller:
1100M
PATHPILOT® CONTROLLER:
Standard Features:
  • Easy to learn, touch screen friendly user interface
  • Built-in recommended speeds and feeds calculator
  • 40GB program memory
  • Built-in Dropbox support for seamlessly transferring programs
770M
Standard Features:
PCNC 440
Standard Features:
