Smart Cool
Revolution Slider Error: Slider with alias smart-cool not found.
Maybe you mean: 'brand-ambassadors' or 'grinder' or 'home-slider' or 'test-slider'
Programmable
SmartCool has three programming modes
that provide pinpoint control of the coolant position:
 Tool tip Mode
Coolant stream automatically adjusts to target the tool tip of each tool stored in the PathPilot tool table.
ZO Mode
Coolant stream automatically adjusts to maintain constant Z-plane target regardless of tool position.
 Wiggle Mode
Coolant stream oscillates to deliver coolant along the entire length of the tool.
Configurable
SmartCool can be adapted to work
with three coolant options.
Expandable
Multi-coolant module allows for both
flood coolant (M7) and mist (M8) coolant support*.
*Requires SmartCool (PN 37167) and Multi-Cool module (PN 37168).
SmartCool with Flood Coolant
SmartCool with Fog Buster
SmartCool with Air Blast
FAQs
SMARTCOOL FAQs
No, SmartCool™ only works with Tormach mills that are powered by the PathPilot™ control system
PCNC 1100™, PCNC 770™, PCNC 440™
It’s Easy. Use G-codes
Load More
