PCNC 440
small machine
BIG RESULTS
PCNC 440 Benchtop Mill
Real CNC For Shops of Any Size
PCNC 440 mill
PCNC 440 CNC Mill PACKAGE OPTIONS
Some Assembly Required
PCNC 440 Entry Level Package
Entry Package
Entry Package for the PCNC 440
Base Price: $6,890
Starter Package
Starter Package for the PCNC 440
Base Price: $8,676
Premium Package
Premium Package for the PCNC 440
Base Price: $13,225
REAL CNC FOR SHOPS OF ANY SIZE
A benchtop mill that fits all-around capability in a small and affordable package, the PCNC 440 is perfect for anybody that wants to perform machining operations but doesn’t have a lot of space.
Features
PCNC 440 logo
PCNC 440 FEATURES
  • Cast Iron Frame and Table
  • Dovetail Ways
  • Ball Screws
  • 10,000 RPM R8 Spindle
  • 10″ x 6.25″ x 10″ Work Envelope
POWERED BY PATHPILOT®
PathPilot® is the next generation control platform for Tormach CNC products, featuring professional-level machine control with an intuitive operator interface.
Technical Specifications
X-Axis: 10″ 254 mm
Y-Axis: 6.25″ 158.75 mm
Z-Axis: 10″ 254 mm
Spindle Power: 0.75 hp 0.56 kW
Maximum Speed: 10,000 RPM
Transmission: Poly-V Belt
Spindle Taper: R8
Thread Machining: Thread Mill
X- and Y-Axis: 135 IPM 3.43 m/min
Z-Axis: 110 IPM 2.79 m/min
Power Required: Single-Phase, 115 Vac 50/60 Hz, 15A Breaker
Table Size: 18″ × 6.30″ 457 mm x 160 mm
Table Slots: 3/8″ – Three slots 9.5 mm – Three slots
Spindle Nose to Table Max. Clearance: 11″ 279 mm
Spindle Centerline to Machine Column: 6.5″ 165 mm
Typical System Footprint: 42″ × 36″ 1067 mm x 914 mm
Overall System Height: 72″ 1829 mm
Typical System Weight: 600 lb 272 kg
Automatic Tool Changer
Power Drawbar
4th Axis (COMING SOON!)
Smart Cool™ Coolant System
Full Enclosure
Flood Coolant
PathPilot® Controller – Standard Features:
  • User friendly design
  • Support for up to 4-axis continuous machining
  • 80 GB of system program memory
PCNC 440 Options
PCNC 440 mill
  • 10 ga. Sheet Metal Construction
  • 1/4″ Thick Polycarbonate Doors (Compare to Lexan)
  • Powder Coated Finish
  • Dual Pivoting Front Doors.  Opening is 23″ x 24″ (W x H)
  • Sliding Side Doors.  Opening is 14″ x 20″ (W x H)
  • Flat Packed, Some Assembly Required.
Eliminate the need to hand-tighten your drawbar and install this Power Draw Bar on your PCNC 440 for lightning-fast tool changes with the push of a button.
The power drawbar is designed for use with the Tormach Tooling System (TTS), but easily pivots away to allow manual tightening of the drawbar if necessary for conventional R8 tooling.
  • Requires 90 psi Air Supply (FRL unit recommended)
  • Designed for use with Tormach Tooling System (TTS) toolholders
  • Multi-stack air-over-air pneumatic cylinder ram actuation
  • Does not load the Spindle Bearings
  • Easily Pivots for Manual drawbar tightening for R8 tooling
The Power Drawbar kit includes pneumatic cylinder assembly stack, drawbar, pneumatic push-button box, and all necessary pneumatic tubing.
power drawbar
  • Powder Coated Sheet metal Construction
  • Front Storage Compartment with Shelf.  Opening is 25″ x 22″ (W x H)
  • Adjustable Leveling Feet
PCNC 440 stand
  • Coolant reservoir tank
  • Coolant Pump
  • Hose Kit, including necessary fittings and mounting brackets.
pcnc 440 atc
  • 8 Station Tool Tray for TTS Tool Holders*
  • Slide activation via Double Acting Pneumatic Cylinder with Cushion
  • Automatic Crash Detection and Warning Prompts
  • Carousel Position Feedback
  • Air Blast
  • Integrates with PathPilot® with graphical interface
PCNC 440 FAQS
Power Drawbar:
Now Available! Click here to buy now.
ATC:
4th Axis:
We are currently developing the PCNC 440 4th Axis but it is too preliminary to estimate an expected availability date.
To purchase a custom package, use the PCNC 440 “Build Your Own” Package. This package can be modified to meet your specific needs. Items can be added and subtracted from the package, as you see fit.
The PCNC 440 is controlled by PathPilot™, Tormach’s control system, used on every PCNC mill. PathPilot™ easily interfaces with most popular CAD/CAM systems but includes onboard conversational programming that can create CNC programs at the machine without the need for a CAD/CAM system.
Many accessories that are available for our two larger mills (PCNC 1100 & PCNC 770) are compatible with the PCNC 440, as well. Like our other mills, the PCNC 440 utilizes our TTS tooling system. Some exclusions are the larger vises, high speed spindle attachments, current 4th axis tables, tool setter, load meter, automatic oiler, and active/digital probes (probes may be available in the future).
It can cut aluminum, steel, titanium, as well as plastics, composites, wood, and PCB boards. Anything our other mills can cut.
The PCNC 440 has a footprint of 40” x 32” x 42” (X x Y x Z) – this is not including the stand (full enclosure does not change the footprint).
Load More
technical support icon
Looking For Help With Your PCNC 440 Mill?
