PCNC 1100
series 3 logo
The third generation of our best-selling small CNC mill
PCNC 1100 Series 3 combines quality components with thoughtful engineering.
Want to know more?
Click For Technical Specs
PCNC 1100 Package Options
Some Assembly Required
Starter Package
Includes PCNC 1100 and essential workholding, tooling, and other accessories to get started.
Base Price: $14,252
Standard Package
Nicely outfitted and a great starter kit for prototypers, small shops, inventors and home hobbyists.
Base Price: $17,551
Deluxe Package
 Includes all the equipment necessary to machine at a professional level and designed with the machinist in mind.
Base Price: 19,830
Part Maker Package
Get started making parts with the Part Maker package, which includes all the tools necessary to outfit a new shop.
Base Price: $26,381
Starter Package
Standard Package
Deluxe Package
Part Maker Package
Base Price: $14,252
Base Price: $17,551
Base Price: $19,830
Base Price: $26,381
OUR  BEST SELLING SMALL CNC MILLING MACHINES
The PCNC 1100 personal CNC mills are our best selling small CNC milling machines and a proven performer for prototyping, short run production, education, and hobby CNC milling.
PN 32085 Tormach PCNC 1100 series 3
THE BEST PERFORMANCE AND AFFORDABILITY IN ITS CLASS
pcnc 1100 full enclosure
Thoughtful design and engineering makes the Tormach personal CNC mill an unrivaled combination of performance and affordability in its class, with the precision to do real work and power to cut the toughest materials – stainless, titanium, even pre-hardened tool steel.
Tormach Advantages
WE OFFER A PACKAGE THAT SUITS EVERYONE
With Tormach it is possible to build your CNC shop any way you like! Our packages are a few examples of how you can configure your PCNC 1100 and accessories to work for you. Using our shopping cart, you can add or subtract items from the packages to create your own custom equipment list.
packages logo
THE LEADER IN SMALL CNC MILLING MACHINES
The Tormach PCNC 1100 personal CNC mill is a new approach in CNC milling machines – a small CNC mill designed for real work with the power to cut serious materials. Milling circuit boards, aluminum, and engineering polymers are a breeze when your CNC milling machine is built to cut materials like steel, iron, stainless, and titanium.
PCNC 1100 personal CNC mills were engineered from the ground up to be the best value in small CNC milling machines. The Tormach PCNC 1100 personal CNC mill was thoughtfully designed with a combination of quality components and proven technology to create an affordable small CNC milling machine that provides unprecedented value in CNC mills.
GREAT PERFORMANCE EXPECTATIONS
The machine is capable of cutting most materials at or near their recommended feeds and speeds. For example, for fast metal removal on 6061 aluminum we will run a 1/2” diameter 2 flute cutter at around 18 IPM (inches per minute) and 3000 RPM, using a full 1/2” depth of cut. That’s a pretty good volumetric rate of metal removal so it’s essential to clear chips with a flood coolant. We will run smaller cutters when we’re not trying to remove large amounts in a hurry. For most aluminum work we use 3/8”. The example above, using a 1/2” cutter, results in a surface speed of 390 SFM (surface feed per minute). A 3/8” cutter needs 4000 RPM to get the same surface speed, well within the performance envelope of the machine.
WE OFFER LOTS OF OPTIONS
When it comes to customizing your PCNC mill Tormach leads the way in available options. Build the perfect cnc machine for your particular need with a wide array of PCNC mill upgrades and add-ons. From enclosures to ATC’s and Power Drawbars, get the options you need for your shop.
Key Features of the PCNC 1100
  • 5140RPM 1.5HP R8 Spindle with Sensorless Vector Control and exclusive foldback logic.
  • Single Phase 230 VAC 50/60 Hz Primary Power Requirement
  • 1400lbs. (Typical system weight with stand)
  • Optional Stand available
  • Polyphase Axis Motion Technology powered by Leadshine®
designed and built to last
Each PCNC 1100 CNC mill has over half a ton of cast iron and steel that is precisely placed to achieve maximum frame rigidity in a footprint that’s about the size of a traditional manual milling machine.
The sliding dovetailed ways are hand-scraped and designed to withstand high loads and dampen vibrations. The ways have bonded PTFE filled acetyl sliding surfaces, hand scraped by skilled machine builders. Similar to brand name compounds such as Turcite® or Rulon®, PTFE compounds provide low friction and long life.
Each PCNC 1100 small CNC mill features an R8 spindle with a 3 3/8″ nose diameter – the same standard dimension as popular Bridgeport -style manual mills. This can be used in combination with the innovative quick-change Tormach Tooling System® (TTS) or any generic R8 tooling.
Technical Specifications
X-Axis 18 in. (457 mm)
Y-Axis 9.5 in. (241 mm)
Z-Axis 16.25 in. (413 mm)
Spindle Power: 1.5 hp (1.12 kW) Brushless AC Induction Motor(optional BT30 retrofit available)
Maximum Speed: 5140 RPM
Transmission: Poly-V BeltLearn More
Spindle Taper: R8
Thread Machining • Tension/Compression
• Auto-Reversing
• Thread Mill
Z-Axis 90 IPM (2.29 m/min)
Power Required Single-Phase 230 Vac,
50/60 Hz, 20A breaker
Table Size 34 in. × 9.5 in.
(863 mm × 241 mm)
Table Slots 5/8 in. (15.9 mm)
(three slots)
Spindle Nose to Table Max Clearance 17 in. (432 mm)
Spindle Centerline to Machine Column 11 in. (279 mm)
Typical System Footprint 69 in. × 56.5 in.
(1753 mm × 1435 mm)
Overall System Height 96 in. (2438 mm)
Typical System Weight 1500 lb (680 kg)
Frame and Table Cast iron frame and table, with
hand-scraped hydrodynamic ways
and tapered adjustment gibs
Way Surfaces Low-friction PTFE-filled,
Acetyl-bonded sliding surface.
Similar to Rulon® and Turcite®.
Automatic Tool Changer
Power Drawbar
4th Axis
SmartCool™ Coolant System
RapidTurn™ Chucker Lathe Accessory
Full Enclosure
High-Speed Spindle
PathPilot® Controller – Standard Features:
  • User-friendly design
  • Support for up to 4-axis continuous machining
  • 80 GB of system program memory
technical support icon
LOOKING FOR HELP WITH YOUR PCNC 1100 MILL ?
