PathPilot Bug and Feature Request List
Type Issue # Title Status Created
bug PP-1419 MIll/Lathe - Reference Move: Spacebar/Feedhold button do not stop axis motion during reference moves open 2017-03-17
bug PP-1343 Lathe - Conversational Radius: Radius code doesn't produce exact circular arc because it lacks compensation for tool radius open 2016-12-20
bug PP-1337 Mill - Probing: Find A Axis Center routine is off in Z by 10 - 30 thousandths of an inch. open 2016-12-08
bug PP-1283 Lathe - Conversational ID Thread: Retract at driveline, not beyond, to prevent collision open 2016-09-26
bug PP-1151 Mill - M3: M3 S0 (spindle run with zero speed) results in machine waiting for at-speed indefinitely open 2016-03-10
bug PP-1125 Mill - Set Start Line: If machine is in G54, and set start line feature is used on a program in G55, and program is aborted half way through, DROs will read in G54 offsets open 2016-01-21
bug PP-1011 Mill - Toolpath preview: Program extents not always displayed on first program load, sometimes you need to change the view to see them. open 2015-08-10
bug PP-866 Mill - Toolpath preview: G code with A axis moves is not always well rendered in tool path preview open 2015-04-06
improvement PP-1351 Lathe: Conversational enhancement: Add internal grooving toolpath functionality open 2017-01-04
improvement PP-1013 Mill/Lathe - Tool tips: add a "learning" mode setting that enables tool tips with descriptions of functions/buttons/dros open 2015-08-13
improvement PP-997 Mill - Conversational: Face routine should accept Z start = Z end open 2015-08-01
improvement PP-988 Mill/Lathe - Touchscreen: Add ability to get right click menu from touch. open 2015-07-20
improvement PP-862 Mill - Conversational enhancement: Add angle wrt X axis to engraving tab open 2015-03-31
improvement PP-825 Mill/Lathe - Settings screen enhancement: Add M codes to the G codes cheat sheet open 2015-03-12
improvement PP-815 Mill/Lathe - Touchscreen: Need soft keyboard for tool table entries open 2015-03-06
improvement PP-804 Touchscreen - Popup lacks Capslock key to allow users to make capital letters via soft keyboard open 2015-03-03
Last modified on May 21, 2019 7:51 AM
