Shipping
Where are you shipping this purchase to?
image/svg+xml United States Canada Australia Europe South America Mexico United Kingdom
Click on a region to view shipping requirements.
United States
When you submit your quote, Tormach’s shipping department will need to know:
  • What you’re buying, to calculate weight and dimensions
  • Whether the destination is commercial, educational or residential.
  • Whether tailgate delivery is needed or not. If you do not have a lift truck or loading dock, you need tailgate delivery.
  • Your zip code.
Canada
  • Your postal code.
  • Which Canadian Broker you’ll be working with. We commonly work with Livingston International, but we can work with anyone you choose.
Please keep in mind this quote does not include the delivery cost, terminal cost, duty cost or any brokerage fees. These are things your freight forwarder can help you estimate.
Australia
  • Your postal code.
  • Which freight forwarder you’ll be working with. We commonly work with IJS Global or Fracht Australia, but we can work with anyone you choose. They will request shipping specifications, including dimensions, weight, location and a harmonized number; view estimated numbers.
Europe
  • Your postal code.
  • Which freight forwarder you’ll be working with. We commonly work with DB Schenker or ACC Shipping Ltd, but we can work with anyone you choose. They will request shipping specifications, including dimensions, weight, location and a harmonized number; view estimated numbers.
South America
  • Your postal code.
  • Which freight forwarder you’ll be working with. We commonly work with Ceva Logistics, but we can work with anyone you choose. They will request shipping specifications, including dimensions, weight, location and a harmonized number; view estimated numbers.
Mexico
  • Your postal code.
  • Which freight forwarder you’ll be working with. We commonly work with Pedraza Forwarding Inc, but we can work with anyone you choose. They will request shipping specifications, including dimensions, weight, location and a harmonized number; view estimated numbers.
UK
  • Your postal code.
  • Which freight forwarder you’ll be working with. We commonly work with Internet Chamber of Commerce (ICC), but we can work with anyone you choose. They will request shipping specifications, including dimensions, weight, location and a harmonized number; view estimated numbers.
Commercial, Educational, or Residential
Commercial: If you select a commercial address, the delivery will be made during normal business hours without an appointment, and a loading dock needs to be available for drop off.
Educational: If you select an educational address, the delivery driver will contact you by phone or email to set up an estimated delivery time and date.
Residential: If you select a residential address, the delivery driver will contact you by phone or email to set up an estimated delivery time and date.
Freight Forwarder Estimated Specifications
These numbers are meant to be used as a reference for freight forwarders, but they are subject to change. Please reference your quote for final specifications.
Example PCNC 1100 Specifications
  • PCNC 1100 Mill
    • Dimensions: 52" x 45" x 63" (1 crate)
    • Gross Weight: 1350 lbs
  • Deluxe Machine Stand, with coolant tank, for PCNC 1100
    • Dimensions: 41" x 45" x 41" (2 crates banded as 1 skid)
    • Gross Weight: 500 lbs
  • Deluxe Accessories Package, for PCNC 1100
    • Dimensions: 48” x 42” x 30” (1 skid)
    • Gross Weight: 845 lbs
Example PCNC 770 Specifications
  • PCNC 770 Mill
    • Dimensions: 45" x 41" x 49" (1 crate)
    • Gross Weight: 800 lbs
  • Machine Stand, with coolant system, for PCNC 770
    • Dimensions: 40" x 36" x 60" (3 crates banded as 1 skid)
    • Gross Weight: 475 lbs
  • Deluxe Accessories Package, for PCNC 770
    • Dimensions: 48” x 42” x 28” (1 skid)
    • Gross Weight: 380 lbs
Example PCNC 440 Specifications
  • PCNC 440 Deluxe Package with Stand (2 skids gross total)
    • Skid 1: 42" x 33" x 67" (4 crates banded as 1 skid)
    • Skid 2: 34" x 23" x 23"
    • Gross Weight: 895 lbs
Example 15L Slant-PRO Lathe Specifications
  • 15L Slant-PRO Lathe
    • Dimensions: 65" x 37" x 65" (1 crate)
    • Gross Weight: 1725 lbs
  • Lathe Enclosure
    • Dimensions: 48" x 40" x 28" (1 skid)
    • Gross Weight: 190 lbs
  • Turret and Accessories skid
    • Dimensions: 48" x 40" x 26" (1 skid)
    • Gross Weight: 320 lbs
Example PSG 612 Automated Surface Grinder Specifications
  • Dimensions: 44" x 36" x 69" (2 crates banded as 1)
Live Help Chat
Live Chat Software
