G47 - Engrave Sequential Serial Number
Details:
To engrave a serial number, either alone or added to the end of any desired text, program: Z~ R~ X~ Y~ P~ Q~ D~
Word
Definition
Z~
The depth of cut of the engraving.
R~
The retract height between character segments in the numbers.
X~
If present, specifies the starting ‘X’ position, or the left side of the serial number. If omitted, the current X position is assumed.
Y~
If present, specifies the starting ‘Y’ position, or the bottom side of the serial number. If omitted, the current Y position is assumed.
P~
If present, is the ‘X’ extent (width) in current units (inches or millimeters) of the engraved number.
Q~
If present, is the ‘Y’ extent (height) in current units (inches or millimeters) of the engraved number.
D~
If present, is the requested number of decimals of the engraved number. If the requested D value exceeds the number of decimals in the serial number, the serial number will show leading zeros. If the requested D value is less than the number of decimals in the serial number, only the digits of the serial number will show. For example: a serial number of 10 where D = 4 engraves as 0010; a serial number of 9056 where D = 3 engraves as 9056.
It is an error if:
  • Cutter Compensation is on
  • The Z number is unspecified
  • The R number is unspecified
