Summary of G-Codes
G00 Rapid positioning
G01 Linear interpolation
G02 Clockwise circular/helical interpolation
G03 Counterclockwise circular/helical interpolation
G04 Dwell
G10 Coordinate system origin setting
G17 XY Plane select
G18 XZ Plane select
G19 YZ Plane select
G20/G21 Inch/millimeter unit
G28 Return home
G28.1 Reference axes
G30 Return home
G38 Straight probe
G40 Cancel cutter radius compensation
G41/G42 Start cutter radius compensation left/right
G43 Apply tool length offset (plus)
G49 Cancel tool length offset
G50 Reset all scale factors to 1.0
G51 Set axis data input scale factors
G53 Move in absolute machine coordinate system
G54 Use fixture offset 1
G55 Use fixture offset 2
G56-58 Use fixture offset 3, 4, 5
G59 Use fixture offset 6/ use general fixture number
G61/G64 Exact stop/Constant Velocity mode
G73 Canned cycle – peck drilling
G80 Cancel motion mode (including canned cycles)
G81 Canned cycle – drilling
G82 Canned cycle – drilling with dwell
G83 Canned cycle – peck drilling
G85 Canned cycle – boring, no dwell, feed out
G86 Canned cycle – boring, spindle stop, rapid out
G88 Canned cycle – boring, spindle stop, manual out
G89 Canned cycle – boring, dwell, feed out
G90 Absolute distance mode
G91 Incremental distance mode
G92 Offset coordinates and set parameters
G92.x Cancel G92 etc.
G93 Inverse time feed mode
G94 Feed per minute mode
G95 Feed per rev mode
G98 Initial level return after canned cycles
G99 R-point level return after canned cycles
