G61 and G64 - Set Path Control Mode
Details:
G61 - Set Exact Path Control Mode
G64 - Set Blended Path Control Mode
Word Definition
P~ If present, specifies the maximum acceptable tool path deviation to round corners to maintain speed. If P is omitted then the speed is maintained however far from the programmed path the tool cuts.
Q~ If present, specifies the maximum deviation from collinearity that will collapse a series of linear G01 moves at the same feed rate into a single linear move.
Note: it is OK to program for the mode that is already active.
