The AF50+ Bandsaw: An Affordable Option To Assist In Automation
  • Our easy-to-use bandsaw is capable of automating cuts
    while you tend to your other production needs.
THE EASY-TO-USE AF50+ AUTOFEED BANDSAW
Download Technical Specifications
The AF50+ Automatic Bandsaw
AF50+ Premium Package
Ideal for efficiently creating multiple parts and automated workpiece placement, our AF50+ Autofeed Bandsaw premium package provides all essentials for cutting stock. It includes a roller table for supporting longer uncut stock lengths. With its consistent part length and hands-free operation, the capable AF50+ bandsaw will compliment your CNC machine seamlessly.
Package Starting At: $5,995
Includes Preselected Build & Tooling Options
Finance for 60 mo. from $127/mo. with Geneva Capital
Not sure if a bandsaw is right for your workflow?
LET THE CAPABLE AF50+ BANDSAW WORK WHILE YOU TEND TO YOUR SHOP
If you own a manual or semi-automatic bandsaw, the easy-to-use AF50+ automatic feed bandsaw offers a refreshing change. With a revamped control panel, featuring new soft-touch buttons, the programmability of the AF50+ lets you focus on more productive tasks while it effortlessly handles uncut stock. With a pneumatic clamping system, you can cut materials from fragile tubing to sizable steel bars.
Enhance your efficiency and creativity, while working on your business. Automate those tedious manual cuts and free yourself from constant supervision. Plus, it operates on single-phase power for added convenience.
AN AFFORDABLE BANDSAW THAT WILL PAY FOR ITSELF
Over time, automated bandsaws prove cost-effective by eliminating the need for constant operator supervision during cuts. With an affordable price point, the AF50+ automatic feed bandsaw can yield returns in just a few months. Particularly for those purchasing pre-cut stock, the impact on savings will be notably evident.
ENGINEERED AND SUPPORTED IN THE USA.
TECHNICAL SPECIFICATIONS
Table Height: 21.75 in. / 552 mm
Length: 50 in. / 1270 mm
Width: 36 in. / 914 mm
Height with Saw at Rest: 36 in. / 914 mm
Height with Saw Vertical: 67 in. / 1702 mm
Motor Power: 1 hp / 0.75 kW
Capacity
7 in (178 mm) Round / 6 in x 8 in (152 mm x 203 mm) Flat at 90 degrees
Blade Speed
60 Hz: 90, 134, 195, 255 ft/min(27, 41, 59, 78 m/min)
50 Hz: 70, 110, 160, 210 ft/min(22, 34, 49, 64 m/min)
Blade Size
Blade Length 93 in. (2362 mm)
Blade Width 0.75 in. (19 mm)
Blade Thickness 0.035 in. (0.9 mm)
Features
  • 115 Vac, Single-Phase Power
  • Pneumatic Clamping System
  • Hydraulic Feed Control
  • Programmable Automatic Workpiece Positioning
    • Cut lengths between 0.157 in – 50 in (4 mm – 1270 mm)
    • Up to 10 in (254 mm) per stroke
    • Maximum 5 strokes per part
    • Maximum 999 parts per program
    • Part countdown display
  • Integrated Coolant System — Tank capacity 2.65 Gal (10L)
  • Recycles Coolant
  • Portable
  • 4 Blade Speeds
  • Blade Tensioning System
Tormach Technical Support
LOOKING FOR HELP WITH YOUR AF50+ BANDSAW?
Visit Our Support Section
Bandsaws
