24R CNC Router
INTRODUCING THE NEW
24R CNC ROUTER
Unrivaled performance
and capability in its class.
Ready to Run at $13,995
Explore Packages
ENTRY PACKAGE
The 24R Router Entry Package has the basics that you will need to get started. This package includes router, controller, chiller and owners kit.
STARTER PACKAGE
The 24R Router Starter Package gets you everything from the Entry Package as well as a monitor and mount, jog shuttle controller, waterproof mouse and keyboard, tool setter, 24R Starter Cutting Tool Kit by Amana Tools and VCarve Pro software.
PRO PACKAGE
The 24R Router Pro Package builds out the Starter Package with the addition of a touchscreen kit, adjustable swing arm, dust collector, vacuum pump, and an upgrade to Aspire software.
Starting at $13,995
(+$395 Shipping)
Starting at $16,041
(+$395 Shipping)
Starting at $19,615
(+$395 Shipping)
Engineered and supported in the usa.
Industrial, Robust Design —
The Ideal Solution for the Premium Woodworker, Signmaker or Dreamer!
Engineered by Tormach’s CNC machine tool professionals to bring your ideas to life!
This computer-controlled 24R CNC Router is designed to accurately cut variety of materials, including aluminum, plastics, wood, and more. With an advanced control, rigid cast-iron bed, welded-steel stand, water-cooled chiller, integrated vacuum table, and more than a 2′ x 4′ work envelope, this router is the perfect choice for all your 2D and 3D cutting needs.
Programming a CNC Router
Just Got Easier!
The advanced PathPilot® CNC control is the magic behind all Tormach machines. We developed it with the features we’d want in a control software. It’s easier to learn and use; and comes with a lifetime of FREE upgrades and support!
PathPilot utilizes standard machine code (G & M), integrates with most industry-standard CAD/CAM programming software packages, includes built-in diagnostics, tool path graphics and more. You’ll experience a full-scale, user-friendly interface – no need to decipher buttons to start making your project dreams a reality.
24R CNC Router
Loaded Up and Ready to Go!
Designed to optimize efficiency and productivity, the 24R CNC Router provides your shop with rigid and accurate cutting, durability, ease-of-use and gosh darn it, it’s pretty nice to look at too!
We’re Keepin’ It Cool … The 24R CNC Router automatically comes with a water-cooled spindle and chiller. We’ve included safety features in PathPilot to ensure you’re ready to start cutting. An integrated alarm will notify you if your spindle isn’t cooling or if the chiller is out of water.
Next Step … Sawdust!
Visit Us at FABTECH and See Our New 24R CNC Router
This machine runs on our very own PathPilot and is ideal for running jobs in wood, plastic and even aluminum.
Technical Specifications
X-Axis: 24.75 in. 625 mm
Y-Axis: 55.75 in. 1415 mm
Z-Axis: 6.70 in. 170 mm
Spindle Power: 2 hp (1.5 KW)
Spindle Type: Electrospindle
Minimum Speed: 10,000 RPM
Maximum Speed: 24,000 RPM
Spindle Taper: ER-20
Thread Machining: Thread Mill
Power Required:
Machine Base: Cast Iron
Gantry: Aluminum
PathPilot® Controller Premium Features are Our Standard:
  • User-Friendly Design
  • User-Definable Macros
  • Trajectory Planner/High-Speed Machining
  • Support For Up To 4-Axis Continuous Machining
  • Visual & Intuitive Conversational Programming
  • Expanded Memory: 80GB of system program memory
  • Second Home Position (Operator Defined)
  • Built-in Dropbox™ Support for Seamlessly Transferring Programs
  • WiFi Ready
  • USB I/O Kits Availble to Support up to 4 USB I/O (16 In/16 Out): Trigger aftermarket accessories such as auxiliary pumps, robotic part loaders, probes, and more.
  • FREE lifetime upgrades
