Automatic Tool Changer
About the PCNC Automatic Tool Changer
The Tormach Tooling System ATC is a 10 tool carousel-style automatic TTS tool changer for the PCNC 1100 and PCNC 770 Mill. The side mounted changer integrates with our existing power draw bar system to automatically change tools via controller command.
Features
- 10 position Tool Tray
- Exchangeable virtual Tool Trays
- Mach3 control software with graphical screenset
- Slide activation via Double Acting Pneumatic
- Cylinder with Cushion
- Integrated Touch-off routine (requires electronic tool setter)
- Swappable and configurable tool designations
- Any tool number can be assigned to any slot and requires no program change
- Automatic Crash Detection and Warning
- Carousel Position Feedback
- Air Blast
Design and Engineering
The Tormach Tooling System ATC emphasizes Tormach’s commitment to providing professional design and engineering at unprecedented value.
The design features a retractable carousel cover for chip protection, and automated air-blast to clear chips from the tool shank. The carousel slides into position with a double-acting air cushioned pneumatic cylinder.
Exchangeable virtual tool trays mean that tooling can be changed en masse by a simple tray swap, allowing a different tray to be dedicated to each job.
Tool pockets can be independently assigned to any tool number, so there’s no need to change existing programs so they match tool tray pockets numbers.
The control software integrates with Mach3, and includes a graphical screenset for quick identification of tool location in the carousel. A built-in integrated tool touch-off routine allows automated tool setting of the entire carousel with a single button (requires optional electronic tool setter). When needed, the ATC can be easily bypassed or used in conjunction with manual tool changes if more than 10 tools are needed for a job.
Carousel position feedback ensures the ATC is in the correct position prior to a tool change. Control software interlocks detect and warn against potential collision scenarios and a low-air pressure warning protects against ATC actuation prior to reaching proper holding pressure.
Upgrades - Automatic Tool Changer Documents
All Upgrades - Automatic Tool Changer Documents
Using the Tormach Tooling System ATC: Operator's Manual for the PCNC 1100 Automatic Tool Changer
Using the Tormach Tooling System ATC: Operator's Manual for the PCNC 770 Automatic Tool Changer
Tracking revision changes to Mach 3 for PCNC machines with installed ATCs; it covers Series II and Series 3 1100 mills and all 770 mills.
Datasheet for the Automatic Tool Changer for Tormach Tooling System
Whitepaper Discussion of design details of the Tormach Automatic Tool Changer (ATC).
Tormach Tooling Trade-In Program for ATC upgrade
Upgrades - Automatic Tool Changer Manuals
Upgrades - Automatic Tool Changer Datasheets
Upgrades - Automatic Tool Changer Technical Documents
Upgrades - Automatic Tool Changer General Policies
