Technical Questions
- What performance (precision, repeatability, etc.) can I expect from a PCNC?
- What is the control software and is it fully configured?
- Does the stepper control system sometimes lose steps?
- Is there a servo driven version available?
- Can the PCNC mill be purchased without controls?
- What is the dovetail surface and will it wear out?
- Why are there two belt positions on the spindle motor?
- Do you need two wrenches to do tool changes?
- What types of ballscrews are used?
- Can I upgrade for increased accuracy?
Please read our PCNC Performance Expectations.
Our machines are delivered with a Mach3 license and a fully developed Mach3 machine control program. While other manufacturers may provide nothing more than a Mach3 profile, Tormach delivers custom screens, accessory plug-ins, special machine macros (M codes), conversational wizards,and more. The standard installation includes functions and features for turnkey support of Tormach accessories, including 4th axis, digitizing electronic touch probe, tool height setters, and electronic hand wheel, duality lathe, and automatic tool changer (ATC). Additionally, our Mach3 installation package is available as a free download on our Support Documents webpage. The software can be operated in an off-line mode so you can see how your machine will operate even before you buy a machine. We maintain and periodically update control software when enhancements warrant. Legacy Tormach machines receive free updates to the latest release.
Proper engineering of a stepper system is not trivial. The fact that stepper driven motion control is commonly used on mission critical systems, such as medical equipment, is testament to the reliability and accuracy of the technology. The technology has been given a black eye by a few poorly designed machines offered by others, as well as a large number of hobby CNC projects. PCNC mills and other properly engineered machinery will not lose position in the designed operating envelope. The PCNC 1100 axis system can deliver 850 lbs of force before missing a step, more than enough to break most cutting tools. Step loss is simply not an issue.
No. Our stepper motor control system is superior to brush style servos in terms of dynamic accuracy, reliability, durability, and cost. Brush style servos do offer higher speed, but we are not willing to accept the compromises associated with brush servos to achieve a bit of speed. Brushless AC servos do not suffer the problems of brush servos, but their cost is prohibitive.. Further details on comparison of axes drive systems can be found on page 7 of our PCNC Design Document.
We do not sell the machine frame without controls for several reasons. Unless a machine is completed it cannot be fully tested for precision and quality. In addition, we do not want any confusion between a home-built Tormach mill and professionally finished Tormach mill. Finally, there is no savings to the consumer. Motors, drives, and other control components cost far more when purchased separately.
The plastic surface is PTFE filled acetyl. Common trade names for this type of material are Turcite or Delron AF. The plastic slide surface is not just a coating, but rather a robust bonded strip, about 1/32” thick. This type of slideway was common on mills in the past but now is only seen on expensive high precision machines such as Hardinge VMCs. The ways must be hand scrapped by experienced technicians. Many machine manufacturers have switched to linear rollers due to labor costs, but manufacturing in China allows us to provide this superior design at a low cost. It’s conceivable that the slideway could get worn out, but it would take a great many hours. To date, we have machines that have been in continuous daily service for over 5 years and have received no reports of worn out slideways . Additional engineering details of the slideway design can be found on page 8 of our PCNC Design Document.
The spindle drive is infinitely variable in speed, but there are practical limits because an induction motor delivers very little power at low speed. The motor/spindle ratio needed for 5000 RPM would not be able to deliver any effective cutting power at 150 RPM. By offering two belt positions, our spindle delivers good torque through a wide speed range. Changing belt positions is rarely needed because there is considerable overlap between the high speed and low speed positions. When a belt change is required, it takes less than a minute and requires no tools.
The spindle has a built in spindle lock. This allows a single wrench to be used for tool changing; allowing your other hand on the tool to prevent it from falling out after it’s loose. There is mechanical interlock on the spindle door which makes it impossible to forget to remove the spindle lock before starting the spindle. Finally, there is an electrical interlock on the spindle door which prevents the spindle from coming on when you’re in the middle of changing a tool. We also offer a pneumatically activated power draw bar for wrench-free tool changing.
We use a ground ballscrew, P4 grade with a double nut. P4 accuracy specification is 0.0006” per foot and is 100% inspected using a laser interferometer. Many commercial machines use a lower grade like P5. P5 screws have a larger tolerance for error and are generally spot inspected, not 100% inspected. Retrofit machines and conversion kits typically use a rolled ballscrew such as Rockford Ball Screws. These are typically ungraded but are roughly equivalent to C7 or C8 with 0.001" to 0.003" error per foot.
We do not offer any accuracy upgrade package, nor would it be practical. The differences between a mill that can consistently deliver 0.001” accuracy and one that can deliver 0.0002” are significant and require changes throughout the machine. There is no magic bullet, or any single component change that will transform the mill into a different beast. Dropping a Corvette engine into a Chevy Impala does not make it a Corvette. Likewise, substitution for higher grade ballscrews, glass scale feedback, or high performance servo, will not deliver a significantly higher level of performance.
