Tormach Technical Documents
Type Title Desc Revision Date Link
TD10460: XTREME CUT 251C SDS This is the safety data sheet (SDS) for XTREME CUT 251C, a cutting and grinding semi-synthetic fluid. 09/23/16
TD10297: Adjustable Tailstock Installation This document details installation of the Adjustable Tailstock on the 15L Slant-PRO lathe. 09/21/16
TD10108: PCNC 770 Moving Kit This document details a safe method of disassembly and reassembly of a PCNC 770 mill to move the machine with ease. 09/21/16
TD10383: Touch Screen Kit Installation This document details installation and calibration of the 17” LCD Touch Screen Monitor on the PCNC 770 mill, PCNC 1100 mill, and 15L Slant-PRO lathe machine arms. 09/20/16
TD10413: Turret Installation on 15L Slant-PRO Lathe This document details installation of the second generation eight-position turret on the 15L Slant-PRO lathe. 09/16/16
TD10390: PCNC 440 Enclosure Installation This document details installation of the PCNC 440 full enclosure. 08/30/16
TD10457: DURAKUT7000B SDS This is the safety data sheet (SDS) for DuraKut 7000B, a premium copolymer based mist lubricant metalworking fluid. 08/19/16
TD10416: Tormach Tooling System Basic Tooling Set This document details use of the TTS Basic Tooling Set. 08/18/16
TD10408: Tormach Tooling System CNC Operator's Set This document details use of the TTS CNC Operator’s Set. 08/18/16
TD10422: SmartCool Install This document details installation and use of the SmartCool programmable coolant system on a PCNC 1100™, PCNC 770™, or PCNC 440™ mill with PathPilot®. 07/22/16
TD10420: PCNC 440 Coolant Control Kit This document details installation and use of a coolant control kit on a PCNC 440 mill. 07/07/16
TD10405: PCNC 440 Flood Coolant Kit This document details installation of a flood coolant kit on a PCNC 440 mill. 07/07/16
TD10370: Motor Quick Change Kit Installation This document details installation of the Quick Change Motor Connection Kit to facilitate use of the High-speed Spindle on PCNC 1100 mills and the RapidTurn on PCNC 1100 and PCNC 770 mills. 05/25/16
TD10392: RapidTurn Certificate of Inspection This is the certificate of inspection for the RapidTurn. 05/25/16
TD10357: Series 1 Axis Driver Replacement This document details the installation of a replacement axis driver on a Series 1 PCNC 1100 mill (only serial numbers between 001-999 and equipped with original Series 1 Axis Drivers). 05/12/16
TD10384: Machine Arm Install This document details installation of a Machine Arm on a PCNC Mill without a full enclosure installed. 05/11/16
TD10360: PCNC 1100 Deluxe Stand Installation This document details the assembly and installation of the PCNC 1100 deluxe mill stand with coolant kit. 05/09/16
TD10039: PCNC 1100 Power Drawbar Installation This document details installation and use of the power drawbar on the PCNC 1100 mill. 05/06/16
TD10128: PCNC 770 Power Drawbar Installation This document details the installation and use of the power drawbar on the PCNC 770 mill. 05/06/16
TD10291: PCNC 770 Full Enclosure Installation This document details installation of the full enclosure on the PCNC 770 mill. 05/02/16
TD10257: PCNC 1100 Full Enclosure Installation This document details installation of the full enclosure on the PCNC 1100 mill. 05/02/16
TD10020: PCNC Mill Comparison This document compares specifications of the PCNC 1100, PCNC 770, and the PCNC 440. 04/26/16
TD10382: Oil Skimmer Kit Installation This document details installation of the oil skimmer on a PCNC 1100, PCNC 770, PCNC 440 or a 15L Slant-PRO lathe. This belt-driven device removes tramp oil from a coolant tank. 04/07/16
TD10396: PCNC Mill Enclosure Door Switch Kit This document details installation and use of the Enclosure Door Switch Kit on either the PCNC 770 mill or the PCNC 1100 mill. 04/07/16
TD10242: Automatic Oiler Installation - 230 VAC This document details installation of the automatic oiler on either the PCNC 1100 mill or the 15L Slant-PRO lathe. 04/07/16
TD10419: Turret Certificate of Inspection This is the certificate of inspection for the Eight-position Turret. 03/29/16
TD10240: 15L Slant-PRO Lathe Certificate of Inspection This is the certificate of inspection for the 15L Slant-PRO Lathe. 03/23/16
TD10295: LED Spindle Light Kit for PCNC Mills This document details installation of the LED Spindle Light Kit on any PCNC mill. 03/09/16
TD10154: PCNC Series 3 Upgrade This document details installation of the PCNC 1100 series 3 upgrade. 03/01/16
TD10141: 4th Axis Homing Kit This document details setup of the 4th Axis Homing Kit with PathPilot to reference a 4th axis to a repeatable home position on a PCNC 1100 and PCNC 770 mill. 03/01/16
TD10173: Drive Replacement Installation This document details axis drive replacement on a PCNC 1100 or PCNC 770 mill and 4th Axis drive installation on a PCNC 1100 or PCNC 770 mill. 03/01/16
TD10244: 15L Slant-PRO Lathe Arm Installation This document details the installation of the lathe arm assembly onto the 15L Slant-PRO Lathe. 03/01/16
TD10249: Lathe Collet Closer Installation This document details installation and use of the 15L Slant-PRO lathe collet closer. 03/01/16
TD10258: Control Relocation Kit This document details the relocation of power controls for either the PCNC 1100 or the PCNC 770 mill when the full enclosure is installed. 03/01/16
TD10368: High-speed Spindle Installation This document details installation, setup, use, and maintenance of the High-speed Spindle Kit on the PCNC 1100 mill. 03/01/16
TD10374: 4th Axis Installation Kit This document details installation and setup of a variety of 4th axis kits. 03/01/16
TD10259: Machine Arm Installation for Mill with Full Enclosure This document details installation of the machine arm assembly on either the PCNC 1100 or the PCNC 770 mill when the full enclosure is attached. 03/01/16
TD10358: PathPilot Quick-start Guide This document details set up of the PathPilot controller for the PCNC 1100, PCNC 770, PCNC 440, and 15L Slant-PRO. 03/01/16
TD10415: PCNC 770 Table Guard Install This document details table guard installation on the PCNC 770. 02/19/16
TD10406: PCNC 770 Flood Coolant Kit This document details installation of the PCNC 770 flood coolant kit and backsplash. 02/19/16
TD10407: PCNC 770 Stand Assembly This document details assembly of the PCNC 770 stand. 02/19/16
TD10144: Fog Buster Installation This document details installation instructions for the Fog Buster kit. 01/28/16
TD10307: Turret Installation on 15L Slant-PRO Lathe This document details installation of the first generation eight-position Turret on the 15L Slant-PRO lathe. 01/18/16
TD10403: PCNC 440 Stand Assembly This document details assembly of the PCNC 440 stand. 01/14/16
TD10105: PCNC 1100 Certificate of Inspection This is the certificate of inspection for the PCNC 1100 mill. 01/05/16
TD10399: Filter-Regulator-Lubricator Installation This document details the installation and use of the Filter-Regulator-Lubricator with the power drawbar and automatic tool changer (ATC). 11/19/15
TD10243: 15L Slant-PRO Chuck Guard Kit Installation This document details installation of the 15L Slant-PRO lathe’s chuck guard assembly. 10/08/15
TD10367: Tormach Vises This document details proper Tormach vise maintenance and care including: 4” Machinist Vise 5” Machinist Vise, and 5” CNC Vise. 09/29/15
TD10140: Load Meter Installation This document details installation and use of the Load Meter on a PCNC 1100 or PCNC 770 mill. 09/24/15
TD10387: 15L Slant-PRO Lathe Light Installation This document details installation of the Lathe Light Kit in the 15L Slant-PRO lathe enclosure. 09/15/15
TD10163: USB I/O Module Installation This document details use of the USB I/O module to integrate external devices with the PathPilot controller. 09/09/15
TD10241: 15L Slant-PRO Lathe Lift Kit Instructions This document details the installation and use of the lift kit for the 15L Slant-PRO lathe to temporarily raise the machine on outrigger legs and allow removal of the shipping pallet below. 07/21/15
TD10379: Water Chiller Treatment MSDS This is the material safety data sheet (MSDS) for Water Chiller Treatment. 07/20/15
TD10077: CNC Tapping Guidelines This document details Tormach’s tapping head options for PCNC 1100 and PCNC 770 mills. 07/07/15
TD10371: SprutCAM V9 Posts This document details installation of updated SprutCAM posts. 06/09/15
TD10220: PSG 612 Certificate of Inspection This is the certificate of inspection for the PSG 612 Personal Surface Grinder. 06/08/15
TD10104: PCNC 770 Certificate of Inspection This is the certificate of inspection for the PCNC 770 mill. 06/08/15
TD10088: Passive Probe Installation Instructions This document details passive probe configuration, calibration, maintenance, and electrical connections (for non-Tormach mills). 05/26/15
TD10315: 15L Slant-PRO Lathe Enclosure Installation This document details the assembly and installation of the 15L Slant-PRO Lathe enclosure. 05/08/15
TD10260: PCNC 1100 DIY Frame Kit This document details the installation of the DIY Frame Kit on the PCNC 1100 mill. 04/29/15
TD10362: TTS Rotary Broach This document details installation and usage of the rotary broach kit. 04/22/15
TD10342: PathPilot Upgrade Kit Install This document is to assist in Tormach controller identification and subsequent installation of the PathPilot Upgrade Kit (if possible). 04/16/15
TD10064: Mach3 Controller Quick-start Guide (PCNC Mill) This document details setup of the Tormach Mach3 mill controller. Legacy document. 04/06/15
TD10320: 15L Slant-PRO Lathe Turret Oil MSDS This is the material safety data sheet (MSDS) for turret oil for the 15L Slant-PRO lathe. 01/27/15
TD10317: DURAKUT 4010 MSDS This is the material safety data sheet (MSDS) for DURAKUT 4010, a light straw or blue colored synthetic metalworking fluid (PN 31750). 12/12/14
TD10246: 15L Slant-PRO Lathe Tool Post Installation This document details the installation of the quick change tool post kit on the 15L Slant-PRO lathe. 09/19/14
TD10178: Refractometer Use Instructions This document details use of the refractometer to check and maintain coolant concentration. 08/12/14
TD10281: Waylube68 MSDS This the material safety data sheet (MSDS) for Waylube 68 machine oil. 07/28/14
TD10038: Automatic Oiler Installation - 115 VAC This document details installation and use of the automatic oiler system on a PCNC 770 mill. 06/26/14
TD10261: DIY Mill Arm Modification for Full Enclosure This document provides do-it-yourself instructions for modifying an existing mill arm to work with a full enclosure on a PCNC 1100 or PCNC 770. 06/12/14
TD10245: D1-4 Chuck Installation This document details the installation of the 3- or 4-jaw Chuck or the 6” Face Plate on the 15L Slant-PRO Lathe. 04/24/14
TD10198: Y-Axis Bellows Upgrade This document details the installation of the Y-axis bellows upgrade kit on PCNC 1100 mills (serial #1-148 only). 11/25/13
TD10102: PCNC 1100 Series 3 Machine Control Software Installation This document tracks revision changes to Mach3 for PCNC 1100 Series 3 machines. Legacy document. 09/13/13
TD10072: Tormach ATC Install Instructions and Software Revision Information. This document tracks revision changes to Mach3 for PCNC 1100 machines that have ATCs installed; covers Series II and Series 3 1100 mills and all 770 mills. Legacy document. 08/30/13
TD10169: Coolant, Cooling, and Related Issues This document details three basic issues that are always a concern when machining using cutting tools: creation of heat from cutting, removal of heat when cutting, and removal of chips. 06/25/13
TD10160: Suppression Kit Installation Instructions This document details the installation of the suppression kit on PCNC mills. 02/18/13
TD10145: Anti-Seize Compound-9070, 9071, 9072 MSDS This is the material safety data sheet (MSDS) for Anti-Seize Compound-9070, 9071, 9072. 08/10/12
TD10146: Perkins Perlube WL-68 MSDS This is the material safety data sheet (MSDS) for Perkins Perlube WL-68. 08/10/12
TD10103: Series II Machine Control Software Installation and Revision Information This document tracks revision changes to Mach3 for PCNC 1100 Series II machines serial #1326-1999. This document also covers non-series II machines (lower serial numbers) equipped with the Spindle Drive Upgrade Kit (PN 31090). Legacy document. 07/17/12
TD10139: PCNC 770 Control Software Install Instructions This document tracks revision changes to Mach3 for PCNC 770 mills. Legacy document. 06/19/12
TD10093: Application Notes for the CNC Drag Knife This document details care, use, and application examples for the CNC Drag Knife. 03/29/12
TD10129: Tormach Super Soft Jaws This document details application examples for the Super Soft Jaws. 03/28/12
TD10046: Integrated E-Stop Installation Kit Instructions This document details the installation of the Integrated E-stop Installation Kit on a PCNC mill. 02/02/12
TD31997: 8" Motorized Tilting Rotary Table QC This is the certificate of inspection for the Tormach 8" Motorized Tilting Rotary Table. 06/29/11
TD31890: Kress Spindle Characterization Characterization of the Kress 800FME spindle. German with English Translation. 03/14/11
TDSprutCAM: SprutCAM 7 Pro Upgrade Installation This document details installation instructions for upgrading SprutCAM 2007 to SprutCAM 7 Pro. Only covers the dongle version of SprutCAM. Legacy document. 03/14/11
TDSprutCAM: PCNC Mill Postprocessor for SprutCAM This document details the changes and improvements made to the new PCNCMasterPostRev1.1 Legacy document. 03/14/11
TDSprutCAM: Duality Lathe Postprocessor for SprutCAM This document details changes and improvements made to the TurnDualityRev1.1 Post. Legacy document. 03/14/11
TD31051: Duality Lathe Control Software Installation and Revision Information This document details Mach3 used with the Duality Lathe when used in conjunction with the PCNC Mill. Legacy document. 11/10/10
TD31455: Tormach CNC Scanner Quick Start Guide This document is the Tormach CNC Scanner quick start guide. 06/08/10
TD30194: 8" Motorized Rotary Table Certificate of Inspection This is the certificate of inspection for the 8" Motorized Rotary Table. 11/17/09
TD30267: 6" Motorized Rotary Table Certificate of Inspection This is the certificate of inspection for the 6" Motorized Rotary Table. 11/17/09
TD30620: M3 Machine Control Software Installation and Revision Information This document is to track revision changes to Mach3 for all non-Series II (serial #1325 and below), without Spindle Drive Upgrade. Series II mills and non-Series II with spindle upgrade use different control software. Legacy document. 11/05/08
TD30204: PCNC 1100 Printer Port Input Output Pins This document details the list of input and output pins on the printer port on the PCNC 1100 and PCNC 770 mills. 02/06/07
Live Help Chat
Live Chat Software
