Replacement Parts
Typically requested spare parts are listed below for convenient online ordering.  Looking for a part not listed here?  A complete list of part numbers can be found in your machine operator's manual and can be ordered in our "Order by Part Number" webpage.
Maintenance/Replacement - Replacement Parts Documents
All Maintenance/Replacement - Replacement Parts Documents
05/03/11 - VFD Datasheet (421 kb)
03/16/10 - PCNC 1100 Exploded Parts View (762 kb)
Exploded view and parts list for the PCNC 1100 series II mill.
03/25/09 - VFD Whitepaper (229 kb)
Design Analysis of the Sensorless Vector Spindle Drive System on the PCNC 1100 Mill.
01/29/09 - SB0009 Drive Calibration (427 kb)
Safety Service Bulletin for spindle drive replacement or adjustment.
11/06/08 - Spindle Cartridge Assembly Drawing (93 kb)
Drawing of the PCNC 1100 Spindle Cartridge Assembly (PN 30305 & 30306).
11/05/08 - SB0018 Mach3 Control Software Info (33 kb)
Mach3 Control Software Information.
01/31/08 - SB0019 Fuse Correction v2 (114 kb)
Service Bulletin on how to install the replacement fuse on the PCNC 1100 mill. This is not necessary on current PCNC 1100 machines.
01/07/08 - Tordrive-200 Microstepper Motor Driver Datasheet (485 kb)
Datasheet on the Tordrive-200 microstepper motor drive found on PCNC 1100 Series 1 mills (PN 30164).
09/22/07 - SB0011 115V Safety Bulleting (PCNC # 148 and earlier) (321 kb)
Safety Service Bulletin for machines #148 and earlier.
06/30/06 - SB0003 Calibrate the Computer Controlled Spindle Speed (380 kb)
Service Bulletin for procedure to calibrate the computer controlled spindle speed for PCNC 1100 serial numbers 001 - 999.
03/30/06 - SB0006 Heat Related Control Faults (300 kb)
Service Bulletin for Heat Related Control Faults.
02/12/06 - SB0005 Software Update (56 kb)
Service Bulletin for Software Update – Repairing the Write Wizard
10/22/05 - SB0002 Change V-Belt Position (246 kb)
Service Bulletin to reduce the time required to change V-belt position.
10/21/05 - SB0001 Limit Switch (138 kb)
Service Bulletin to increase life and reliability of the Y axis limit switch.
Maintenance/Replacement - Replacement Parts Manuals
Maintenance/Replacement - Replacement Parts Datasheets
Maintenance/Replacement - Replacement Parts Technical Documents
Maintenance/Replacement - Replacement Parts Drawings
Maintenance/Replacement - Replacement Parts Service Bulletins
Maintenance/Replacement - Replacement Parts General Policies
