Electronic Tool Setter
About the Tool Setter
The Tormach Tool Setter (PN 31875), is typically used to measure and set tool lengths and Z-axis work offsets. When contacted by a tool it works with the machine control software to record position. The tool setter enables fast and accurate measurement of tools and setup of jobs. It also has the advantage of setting work offsets with no risk of chipping the edges of high performance carbide mills. The too setter cable has a male 5 pin DIN connector. This connector will join to the auxiliary socket provided on the PCNC operators control panel. The Tormach Tool Setter also comes with a sturdy storage case.
TTS - Touch Probes and Tool Setter Documents
All TTS - Touch Probes and Tool Setter Documents
05/03/12 - U10044M: Tormach Tooling System Manual (844 kb)
03/29/12 - TD10088: Passive Probe Installation Instructions (125 kb)
Instructions for how to configure your PCNC mill to use with the Tormach Passive Probe.
03/19/12 - DS10000: TTS Electronics Datasheet (302 kb)
TTS - Touch Probes and Tool Setter Manuals
TTS - Touch Probes and Tool Setter Datasheets
TTS - Touch Probes and Tool Setter Technical Documents
TTS - Touch Probes and Tool Setter Drawings
TTS - Touch Probes and Tool Setter Service Bulletins
TTS - Touch Probes and Tool Setter General Policies
