Tormach Closed for Memorial Day Holiday
Tormach will be closed Monday, May 27th (5-27-13) for the Memorial Day Holiday.
Orders received after 1:00pm(CST) on Friday, May 24th (5-24-13) will not be processed until Tuesday, May 28th (5-28-13).
Passive Probe
About the Passive Probe
The passive probe is suitable for hobby or occassional probing.  It is simple in design and uses a normally-closed sensing logic.
Probe Sense Logic Normally Closed
Deviation of tip from ideal sphere
Nominal: 0.118" (3.0mm)
Tolerance: +/-0.0002" (0.005mm)
Swing Arm Return Positon Repeatability +/-0.0005" (0.013mm)
Positional Tolerance of tip +/-0.0005" (0.013mm)
Trigger Force (Nominal at stylus tip) X,Y: 1.6-2.5 oz (45-78 g)
+Z: 20.1 oz (570 g)
Stylus Compatability Compatible with Renishaw M4 Stylus family
Electrical Protection Classification IP 66
Spindle Mount System
10mm shank diameter. Recommended Holders:
  • Low Profile 10mm TTS holder (PN32018)
  • ER Collet Holder with 10mm collet.
Overtravel displacement X,Y: 15° from normal
+Z: 0.1969" (5mm)
TTS - Touch Probes and Tool Setter Documents
All TTS - Touch Probes and Tool Setter Documents
05/03/12 - U10044M: Tormach Tooling System Manual (844 kb)
03/29/12 - TD10088: Passive Probe Installation Instructions (125 kb)
Instructions for how to configure your PCNC mill to use with the Tormach Passive Probe.
03/19/12 - DS10052: Tormach Tooling System Catalog (3278 kb)
03/19/12 - DS10000: TTS Electronics Datasheet (302 kb)
TTS - Touch Probes and Tool Setter Manuals
TTS - Touch Probes and Tool Setter Datasheets
TTS - Touch Probes and Tool Setter Technical Documents
TTS - Touch Probes and Tool Setter Drawings
TTS - Touch Probes and Tool Setter Service Bulletins
TTS - Touch Probes and Tool Setter General Policies
