Tormach Tooling System - Jacobs Taper Tools
About Jacobs Taper Arbors and Drill Chucks
Jacobs taper (JT) arbors are used to mount both keyed and keyless drill chucks. They are an affordable option for many typical drilling applications and have versatility to accomodate a range of drill sizes with a single drill chuck.
We have TTS arbors for common JT tapers as well as compatible keyed and keyless drill chucks. To order, simply match your drill chuck size to the corresponding arbor.
Jacobs taper chucks are only suitable for drills and should never be used for milling or other side cutting loads, since these types of cuts will tend to loosen the chuck from the arbor.
TTS - Jacobs Taper Tools Documents
All TTS - Jacobs Taper Tools Documents
Tormach Tooling System Catalog
TTS Jacobs Taper Tools Datasheet
Tormach Tooling System Introduction
TTS Tool Sets Datasheet
Best practices and proper maintenance with R8, ER, Morse and other collet systems can greatly improve tool holding
TTS - Jacobs Taper Tools Manuals
TTS - Jacobs Taper Tools Datasheets
TTS - Jacobs Taper Tools Technical Documents
