TTS - End Mills
About Modular Insert Tooling - End Mills
End mill cutters are the first choice for general material removal - they can be used for facing, pocketing, and profiling. Tormach’s modular tooling system uses modern insert geometries with high positive rake angles for the best of both worlds – high metal removal rates and low cutting forces – allowing the same cutter to be effective for both roughing and finishing. The default quantity shown will add all parts necessary to make a complete tool. Modify the quantity as needed to include extra replacement parts or alternative length mounts.
TTS - Modular Insert Tooling Documents
All TTS - Modular Insert Tooling Documents
08/10/12 - TD10145: Anti-Seize Compound-9070, 9071, 9072 MSDS (27 kb)
Materials Safety Data Sheet for Anti-Seize Compound-9070, 9071, 9072
05/03/12 - U10044M: Tormach Tooling System Manual (844 kb)
03/19/12 - DS10052: Tormach Tooling System Catalog (3278 kb)
03/19/12 - DS10118: TTS Catalog Introduction (768 kb)
Tormach Tooling System Introduction
03/19/12 - DS10123: TTS Modular Insert Tooling Datasheet (1275 kb)
10/26/10 - Preventing Collet Slip (1002 kb)
Best practices and proper maintenance with R8, ER, Morse and other collet systems can greatly improve tool holding
TTS - Modular Insert Tooling Manuals
TTS - Modular Insert Tooling Datasheets
TTS - Modular Insert Tooling Technical Documents
TTS - Modular Insert Tooling Drawings
TTS - Modular Insert Tooling Service Bulletins
TTS - Modular Insert Tooling General Policies
