TTS - Center Cut End Mills
About Modular Insert Tooling - Center Cut End Mills
Center-cutting end mills are used for plunge cutting – they can be fed straight into the workpiece in a similar way to a drill. Center-cutting insert geometries are designed to give the best performance combination in both plunging and side cutting, eliminating the need for separate tools and reducing tooling changes. The default quantity shown will add all parts necessary to make a complete tool. Modify the quantity as needed to include extra replacement parts or alternative length mounts.
TTS - Modular Insert Tooling Documents
All TTS - Modular Insert Tooling Documents
05/03/12 -
U10044M: Tormach Tooling System Manual
(844 kb)
03/19/12 -
DS10052: Tormach Tooling System Catalog
(3278 kb)
03/19/12 -
DS10118: TTS Catalog Introduction
(768 kb)
Tormach Tooling System Introduction
03/19/12 -
DS10123: TTS Modular Insert Tooling Datasheet
(1275 kb)
10/26/10 -
Preventing Collet Slip
(1002 kb)
Best practices and proper maintenance with R8, ER, Morse and other collet systems can greatly improve tool holding
TTS - Modular Insert Tooling Manuals
05/03/12 -
(844 kb)
TTS - Modular Insert Tooling Datasheets
03/19/12 -
(3278 kb)
03/19/12 -
(768 kb)
03/19/12 -
(1275 kb)
TTS - Modular Insert Tooling Technical Documents
10/26/10 -
(1002 kb)
