TTS Modular Insert Tooling
Tormach Tooling System - Modular Insert Tooling Menu Modern carbide insert tooling with interchangeable TTS components lets you create your own custom cutting system.  Learn more here.
About Modular Tooling
Tormach’s Modular Insert Tooling is an interchangeable system of carbide insert cutters, cutter heads, and TTS cutter mounts for the ultimate in flexible quick-change cutting tools.
Face Mills
Face Mills are suitable for surfacing and light side milling.  They fit on to a shell arbor and use replaceable inserts.
Face Mills
End Mills
End mill cutters are the first choice for general material removal - they can be used for facing, pocketing, and profiling.
End Mills
End Mills - Center Cut
Center-cutting insert geometries are designed to give the best performance combination in both plunging and side cutting, eliminating the need for separate tools and reducing tooling changes.
Toroidal Cutters
Toroidal cutters use round inserts that can be repositioned multiple times for a continuous cutting edge.  These cutters are a great choice of economical material removal.
Toroidal Cutters
Ball Precision Cutters
Ball precision cutters are used for finish 3D contouring and surface shaping. They use a single rounded insert to carve both concave and convex shapes.
