Tormach Tooling System - Set Screw Holders
Set Screw holders are our most popular and affordable tool holders. They are commonly used for general milling applications. Set screw holders are intended to be used with end mills that have a Weldon flat on them. They can also be used with certain Silver & Deming style drill bits. Simply match the toolholder size to the shank size of your cutter you wish to hold.
Set Screw holders are best used with 1/4” diameter tools and larger. Holders are available for common Inch and Metric tool shank sizes.
TTS - Set Screw Holders Documents
All TTS - Set Screw Holders Documents
05/03/12 -
U10044M: Tormach Tooling System Manual
(844 kb)
03/19/12 -
DS10052: Tormach Tooling System Catalog
(3278 kb)
03/19/12 -
DS10122: TTS Set Screw Holders Datasheet
(368 kb)
10/26/10 -
Preventing Collet Slip
(1002 kb)
Best practices and proper maintenance with R8, ER, Morse and other collet systems can greatly improve tool holding
TTS - Set Screw Holders Manuals
05/03/12 -
(844 kb)
TTS - Set Screw Holders Datasheets
03/19/12 -
(3278 kb)
03/19/12 -
(368 kb)
TTS - Set Screw Holders Technical Documents
10/26/10 -
(1002 kb)
