Digitizing Probe
About the Digitizing Probe
Tormach offers an electronic Digitizing Probe which enables faster setup of jobs on the machine. The probe is used to set the work offset values corresponding to the position of the work on the table or in the vise. It has a standard TTS (¾") shank and is best used in the ¾" R8 collet (PN 30146). The probe cable has a male 5 pin DIN connector. This connector will join to the auxiliary socket provided on the PCNC operators control panel. The Tormach Digitizing Probe also comes with a sturdy storage case.
| Probe Sense Logic | Normally Open |
| Ball Diameter |
Nominal: 0.118" (3.0mm) |
| Deviation of tip from ideal sphere |
+/-0.00001" (0.00025mm) |
| Swing Arm Return Positon Repeatability | +/-0.00001" (0.00025mm) |
| Positional Tolerance of tip | +/-0.00001" (0.00025mm) |
| Trigger Force (Nominal at stylus tip) | X,Y: 1.6-2.5 oz (45-78 g) +Z: 20.1 oz (570 g) |
| Stylus Compatability | Probe is compatible with Renishaw M4 Stylus |
| Electrical Protection Classification | IP 66 |
| Spindle Mount System | TTS; 3/4" Shank diameter |
| Overtravel displacement | X,Y: 15° from normal +Z: 0.1969" (5mm) |
TTS - Touch Probes and Tool Setter Documents
All TTS - Touch Probes and Tool Setter Documents
Instructions for how to configure your PCNC mill to use with the Tormach Passive Probe.
TTS Electronics Datasheet
TTS - Touch Probes and Tool Setter Manuals
TTS - Touch Probes and Tool Setter Datasheets
TTS - Touch Probes and Tool Setter Technical Documents
