Deluxe CNC Mill Stand
Deluxe CNC Stand
The Deluxe Machine Stand has been designed to maximize efficiency of your PCNC 1100. Chips and coolant stay contained with its generous tray depth, back and side guarding. The table mounted guard shields in the forward direction, while the integrated coolant system keeps you running at maximum speeds and feeds. Stands are shipped via truck freight. Shown with the PCNC 1100 mill (not included).
  • Drip channeling
  • Full width coolant collection
  • 18” high corner wrapping backsplash
  • Four universal electrical openings
  • Computer cabinet vents
  • Removable table guard with clearance for vise
  • 6.5 gallon integrated coolant tank with115/230 VAC configurable coolant pump
  • Chip sieve and catch tray
  • Includes all required plumbing, with flex nozzle and flow control valve
  • Precision-aligned machine mounting pads
  • Computer compartment
  • Storage compartment
  • Adjustable foot pads
  • Easily moved with pallet jack or forklift
  • Access panel for lubrication pump
  • Stainless steel front guard
Deluxe CNC Stand Details
The Deluxe Stand includes an integrated coolant kit with large chip trays and a backsplash surround, as well as a table mounted splash guard. It is suitable for flood coolant and contains the majority of chips and cutting fluids while still providing the versatility of an open-framed machine.
The coolant system is housed in its own cabinet inside the base pedestal. The silver horizontal handle is a pull-out chip collection drawer. The big blue hose drains down to the tank. The pump is on the left of the tank, with a shielded hose running up to the machine action. The tank and tray are welded steel with integrated skim baffles. The coolant pump is configurable for either 115/230 VAC.
Opposite the coolant cabinet is another cabinet. This is intended for the control computer. An additional front storage cabinet includes interior shelves for holding small tools.
The stand feet come with extra long studs. When adjusted, a pallet jack can be slid underneath to easily move the machine if it needs to be relocated. This makes it easy to use the machine for secondary operations. Just park it next to whatever VMC that is used for the primary machining.
The Deluxe Stand requires minor assembly. This saves considerably in shipping cost while also making it easier to put the machine on the stand – the chip trays can be attached after the machine has been lifted on to the base pedestal. Sealing with a bead of general purpose silicone sealant is strongly encouraged to prevent leaks between the chip trays and pedestal and should be applied to the mating surfaces of the pedestal during initial setup.
The Deluxe Stand includes the base, coolant pump, coolant tank, coolant hose, back splash and the table mounted guard. It does NOT include the LCD monitor or machine arm.
Approximate weight of the stand package is 500 lbs. It comes in two crates, banded together
Crate #1: 350 lbs gross 44.5" x 41.3" x 30.4" (L x W x H)
Crate #2: 150 lbs gross 44.9" x 40.0" x 13" (L x W x H)
For USA and Canadian shipments the stands and mills are shipped truck freight while all other accessories are shipped UPS. International shipments other than Canada are consolidated for a single LCL (Less than Container Load) shipment.
PCNC 1100 - Options - Machines Arm and Stands Documents
All PCNC 1100 - Options - Machines Arm and Stands Documents
04/23/12 - PCNC 1100 Series 3 Exploded View (1124 kb)
Exploded view and parts list for the PCNC 1100 Series 3 mill.
04/23/12 - PCNC 1100 Series 3 Manual (6913 kb)
Manual for the PCNC 1100 Series 3 Mill
12/09/11 - PCNC 1100 Dimensions (121 kb)
Document showing the PCNC 1100 mill height and width for space planning.
10/14/11 - DIY Stand Drawings (2587 kb)
DIY Plywood Stand Drawing for PCNC 1100
09/22/11 - Tormach PCNC 1100 Deluxe Stand and Machine Arm Assembly Manual (1002 kb)
Assembly Manual for the Tormach PCNC 1100 Deluxe Stand and the Tormach PCNC Machine Arm
08/25/11 - PCNC 1100 Series 3 and Accessories Datasheet (995 kb)
09/14/07 - Guard Kit & Extended Guard Datasheet (431 kb)
Datasheet on the Guard Kit and Extended Guard for the PCNC 1100 mill
07/19/07 - Machine Arm Datasheet (529 kb)
Datasheet on the optional Machine Arm for PCNC mills.
PCNC 1100 - Options - Machines Arm and Stands Manuals
PCNC 1100 - Options - Machines Arm and Stands Datasheets
PCNC 1100 - Options - Machines Arm and Stands Technical Documents
PCNC 1100 - Options - Machines Arm and Stands Drawings
PCNC 1100 - Options - Machines Arm and Stands Service Bulletins
PCNC 1100 - Options - Machines Arm and Stands General Policies
