Tormach PSG 612 - Personal Surface Grinder
2-Axis Automatic Surface Grinder. Adjustable feed, speed, and stroke length. Cast Iron construction, with hand scraped slide ways and tapered gib adjustment.
  • Wheel size: 7"x 1-1/4" x 1/2"
  • Table Size: 6"x 12"
  • 4 Automatic grinding modes
  • Space-saving footprint for small shop
  • Includes welded steel pedestal
  • 12 mos. factory warranty
Tormach PSG 612 Personal Surface Grinder
Overview
Technical Specifications
Images
Videos
Documents
  • Product Overview
    The Tormach PSG 612 is designed as an economical solution to automate repetitive surface grinding tasks in the small shop. It features automated longitudinal and cross feed with 4 selectable grinding patterns, making it a perfect choice for delivering consistent results for small batch surface grinding operations.
    Each PSG 612 is engineered for a lifetime of worry-free operation. The rigid cast iron frame features a stout column that resists wheel deflection. Slide ways are hand scraped dovetails with taper gib adjustments, and each sliding surface is bonded with a low friction PTFE-filled acetyl co-polymer, similar to Turcite® or Rulon®. A single shot lubrication system distributes oil to all key surfaces with one pull.
    Like all Tormach products, the PSG is backed with a standard 12 month warranty and our industry-best technical support. With a space-saving footprint, simple operator's interface, and robust electronics, the Tormach PSG 612 is ready to take on your next short run or small batch surface grinding job today.
    Learn More...
    Learn more about the engineering behind Tormach PSG612 Personal Surface Grinder from our ED10188: Tormach PSG 612 Design Analysis .
    Review additional grinder options in our online store to select the accessories that are right for you.
    Find out more about Tormach, the latest news and upcoming events, or read the Tormach story to learn more about Tormach's affordable personal CNC milling machines and start enabling your ideas with Tormach!
  • PSG 612 Surface Grinder Technical Overview
    The Tormach PSG 612 is a small footprint 2-axis automatic surface grinder designed for small shop and light industrial applications.
    Technical Specifications: PSG 612 Surface Grinder
    Key Dimensions/Weight
    Table Size: 6" x 12"
    Table Slots: 1 T-Slot: 1/2" x 15-1/2"
    Travel: 13.5" x 8" x 9" (X,Y,Z)
    Longitudinal (X) Max Travel: 13-7/8"
    Crossfeed (Y) Max Travel: 8-1/4"
    Min/Max Distance to Spindle Center from Table: 3"/12"
    Max Working Height: 8 3/4"
    Elevation (Z) Graduation: 0.001"
    Floor to Table Height: 40"
    Space Required for Full Range of Motion: 51"W x 66"H x 30"D
    Stand Footprint: 24" x 24"
    Shipping Weight: 720 lbs
    Machine Weight: 400 lbs
    Crate Dimensions: 43-1/2"W x 66"H x 30"D
    Max Workpiece : 400 lbs Maximum
    Power Requirements: Single Phase, 115VAC 50/60Hz. 8A Peak / 4A Continuous. 15A Breaker recommended.
    Iron
    Frame and Table: Cast iron frame and table, with hand scraped hydrodynamic dovetail slideways and tapered adjustment gibs
    Way Surfaces: Low friction PTFE-filled Acetyl bonded sliding surface. Similar to Rulon® and Turcite®
    Spindle Motor: Industrial Grade 3/4HP TEFC Single Phase Induction Motor. 115 VAC, 60 Hz. 7A Peak Current.
    Wheel Size: 7" x 1-1/4" x 1/2"
    Wheel Speed: 3450 RPM (@ 60 Hz), providing 6300 SFM (with 7" Wheel)
    Motion
    Feed Rate:
    • 0-45 FPM (X)
    • 0-24 FPM (Y)
    Axis Drives (X,Y): High Performance Stepper
    Motors with Leadshine® Microstepping
    Drivers. - Learn More
    Locomotion:
    • Longitudinal (X): Rack and Pinion (automatic)
    • Crossfeed (Y): Leadscrew w/ anti-backlash nut (manual or Automatic)
    • Vertical (Z): Leadscrew w/ anti-backlash nut (manual)
    Control
    Operator Console:
    • Wheel On/Off
    • Automatic Mode Select (4 modes)
    • Longitudinal (X) and Crossfeed (Y) speed control
    • Power On
    • E-Stop
    Other Features
    Paint: 2-Part Copolymer enamel: Cross-linked Acrylic / modified amino resin
    Stand: Heavy Gauge Sheet Metal with Storage Cabinet and Adjustable Foot pads
    Lubrication: Single Shot Distribution, 5 Points. Optional Automatic Oiler available.
  • PSG 612 Tormach Personal Surface Grinder Images
    Product Images
    Click thumbs to enlarge
    • Setting up a Tormach PSG 612 Personal Surface Grinder
      Watch Now
    • Surface Grinder Basics - How to Dress a Magnetic Chuck - Tormach
      Watch Now
    • Tormach PSG612: Belt Attachment Sneak Peek
      Watch Now
    • Surface Grinder Basics: How to Square a Block (6 sides) - Tormach
      Watch Now
    • Introducing The Tormach Personal Surface Grinder
      Watch Now
  • PSG 612 - Personal Surface Grinder Documents
Live Help Chat
Live Chat Software
