CNC Mill Upgrades
CNC Mill Upgrades Own an older PCNC? No problem – with Tormach’s modular system approach to machine design, even the oldest machines can be upgraded to our latest product specifications. Upgrade your mill with a sensorless vector digital spindle drive, power draw bar, Automatic Tool Changer (ATC), and more.
Modular Design is one of the principle features of our PCNC Mills.  We recognize and respect the sizeable investment you made when you purchased your PCNC, and are commited to providing upgrade kits so your mill can be brought up to the same performance specifications of our current product line.  Click on any of the links below to see what upgrades are available for your mill, based on its model and serial number.
Upgrades
1100 Upgrades Chart
Confused about what upgrades or options are available for your PCNC Mill?  Click here to see what's available for each model, arranged by Serial Number.
1100 Upgrades Chart
Polyphase Axis Motors with Leadshine Drivers
Upgrade your PCNC axis motors and drivers to the latest ultra-quiet technology from Tormach and Leadshine.  Up to 120 IPM XY motion, an enhanced torque profile, and more.  Standard Equipment on PCNC Series 3 mills.
Sensorless Vector Spindle Drive
Provides improved spindle torque, better dynamic speed response, and more.  Standard Equipment on PCNC Series 2 and later.
An Automatic Tool Changer (ATC) for Tormach PCNC personal CNC milling machines and Tormach Tooling System (TTS) tool holders.
Power Drawbar
A pneumatically actuated power drawbar for PCNC milling machines that enables wrench-free tool changes. Designed for use with TTS tool holders.
Power Drawbar
Spindle Load Meter
The Load Meter offers a way to visually monitor spindle load.  Use it to identify overload conditions, monitor tool wear, and troubleshoot drive issues.
Spindle Load Meter
BT30 Spindle Cartridge
A drop-in substitute for the factory standard R8 spindle included with the PCNC 1100 mill, suitable for use with most BT30 toolholders.  Designed for use with drawbar; will not work with pull studs.  Not compatible with Tormach Tooling System® ATC
Automatic Oiler
A programmable automatic oiler for worry-free mill lubrication with configurable settings for stroke length and time interval.
Automatic Oiler
E-Stop Kits
Add additional stop buttons to your mill. More than one Integrated Remote E-stop can be linked together in series to provide multiple stop locations.
E-Stop Kits
Other Upgrades
Here are some other upgrade kits, both large and small, that are available for legacy PCNC Mills.  Check your model and serial number to see if they apply to your mill.
Other Upgrades
