1100 Machine Arm & Table Guards
About the Machine Arm
The machine arm can be mounted directly to either side of the machine column. It features a rigid machined cast iron support bracket with two sturdy steel extension arms and a center pivoting hinge. It is fully adjustable and easy to install. Any LCD with a standard VESA 75 mm or 100 mm mount can be attached with the included hardware kit.
Every PCNC machine comes with the column drilled and tapped to fit our cast iron bracket. The supporting arms are machined to allow for routing of the cables inside the arms. Please note, LCD displays and keyboards will require appropriate extension cables when used with the Machine Arm
About the Machine Arm Tool Tray
The Tool Tray is typically mounted on a Machine Arm (sold separately) and can hold up to 20 tools. The laser-etched aluminum tray features a handsome black anodized finish with numbered tool slots.
About the PCNC 1100 Table Guard
The 9" table guard is highly recommended if you plan to use your PCNC 1100 for dry cutting only. This item is included with the deluxe stand.
Extended Table Guard for PCNC 1100
The extended guard is 18" tall and works with the regular guard metal frame.
PCNC 1100 - Options - Machines Arm and Stands Documents
All PCNC 1100 - Options - Machines Arm and Stands Documents
Exploded view and parts list for the PCNC 1100 Series 3 mill.
Manual for the PCNC 1100 Series 3 Mill
Document showing the PCNC 1100 mill height and width for space planning.
DIY Plywood Stand Drawing for PCNC 1100
Assembly Manual for the Tormach PCNC 1100 Deluxe Stand and the Tormach PCNC Machine Arm
PCNC 1100 Series 3 and Accessories Datasheet
Datasheet on the Guard Kit and Extended Guard for the PCNC 1100 mill
Datasheet on the optional Machine Arm for PCNC mills.
PCNC 1100 - Options - Machines Arm and Stands Manuals
PCNC 1100 - Options - Machines Arm and Stands Datasheets
PCNC 1100 - Options - Machines Arm and Stands Technical Documents
PCNC 1100 - Options - Machines Arm and Stands Drawings
