High Speed Spindles
Companion spindle options for high speed light milling and engraving, as well as our patented* Tormach Speeder - a 3x RPM mechanical RPM multiplier. All options are compatible with common Bridgeport quill dimensions.
We offer several affordable options to increase spindle speed for engraving and light milling applications. Companion spindles are desinged to be mounted to the side of the primary milling head. The Tormach Speeder™ is a mechanical speed multiplier that interfaces directly with the native spindle. All options will fit either PCNC mill. They are also compatible with a number of other CNC and Bridgeport-style manual milling machines that use the popular 3 3/8" spindle nose diameter standard.
High Speed Spindles
Companion Spindles
Companion spindles are affordable options to achieve high spindle speed for specialty machining operations. We offer two high quality variable speed die grinders that are appropriate for fine milling and engraving applications.
Speeder
The Speeder is a RPM multiplier for Tormach PCNC mills and other mills with Bridgeport style quills. It multiplies native spindle speed by 3x using belt driven power transfer and a dynamically balanced sub spindle.
