CNC Milling Accessories
Accessories to expand the utility of your mill – Dedicated CNC controllers and companion high speed spindles, as well as Tormach exclusive accessories like CNC Scanner™ and the Tormach Speeder.
Milling Accessories
High Speed Spindles
Companion spindle options for high speed light milling and engraving, as well as our patented* Tormach Speeder - a 3x RPM mechanical RPM multiplier. All options are compatible with common Bridgeport quill dimensions.
Controllers, Pendants & Cables
Dedicated Machine Controllers that feature MachOS or Ubuntu Linux - the most reliable controller for affordable motion control. Tormach also has a variety of pendants, cables, monitors, and other controller accessories.
Gauges and Testers
Tormach features a select group of affordable precision gauges for setting up part programs, verifying measurements, and maintaining optimum machine performance.
Tormach CNC Scanner™
The Tormach CNC Scanner turns your PCNC into a high resolution 2D optical scanner & reverse engineering system. This unique tool has hundreds of uses, including toolmaking, artistry, repair & restoration, precision measurement, & quality assurance.
Probe and Toolsetter
Tormach’s digitizing touch probes and electronic tool setters interface with your PCNC to simplify precision job setup and measurement.
Duality Lathe ™
The Duality Lathe mounts on the bed of the PCNC 1100 to turn your mill into a light duty CNC lathe for prototyping and small turning projects.
Specialty Tools for CNC
Your spindle isn’t just for mills and drills – we have Drag Knives and other unconventional cutting tools for use with your PCNC Mill.
