PCNC 770 Arms and Stands
About the PCNC 770 Stand
The PCNC 770 stand is a welded steel base designed to support the weight of the PCNC 770 without compromising portability – a pallet jack can be easily positioned underneath the base when the mill needs to be moved. Includes generous left and right side chip trays with leak resistant drip channeling, leveling feet, and storage compartments for both tools and control computer. Shown with the PCNC 770 mill (not included). There is an additional truck freight charge for this item. Please see our Shipping webpage for more information.
Coolant Kit for PCNC 770
This flood coolant kit is highly recommended for general metal cutting. The kit includes a coolant reservoir tank, pump, hose, and necessary fittings and mounting brackets. It also includes a backsplash surround and chip guard. Shown with the PCNC 770 mill and stand (not included) There is an additional truck freight charge for this item. Please see our Shipping webpage for more information.
Table Guard for PCNC 770
The chip guard is highly recommended if you plan to use your PCNC 770 for dry cutting only. This item is included in the coolant kit.
About the Machine Arm
The machine arm can be mounted directly to either side of the machine column. It features a rigid machined cast iron support bracket with two sturdy steel extension arms and a center pivoting hinge. It is fully adjustable and easy to install. Any LCD with a standard VESA 75 mm or 100 mm mount can be attached with the included hardware kit.
Every PCNC machine comes with the column drilled and tapped to fit our cast iron bracket. The supporting arms are machined to allow for routing of the cables inside the arms. Please note, LCD displays and keyboards will require appropriate extension cables when used with the Machine Arm
About the Machine Arm Tool Tray
The Tool Tray is typically mounted on a Machine Arm (sold separately) and can hold up to 20 tools. The laser-etched aluminum tray features a handsome black anodized finish with numbered tool slots.
PCNC 770 - Options - Machine Arm Stands and Coolant Kit Documents
All PCNC 770 - Options - Machine Arm Stands and Coolant Kit Documents
05/22/12 - D40275: PCNC 770 Dimensions Drawing (214 kb)
Document showing the PCNC 770 height and width for space planning.
07/07/11 - Assembly Instructions for the PCNC 770 Stand and Arm (1396 kb)
Assembly of the Tormach PCNC 770 Stand and the Tormach PCNC Machine Arm
03/05/10 - D40281: PCNC 770 Base Drawing (20 kb)
PCNC 770 base drawing, detailed and dimensioned. Provided to assist people planning their machine stand.
01/26/10 - PCNC Coolant and Way Oil Datasheet (177 kb)
09/14/07 - Guard Kit & Extended Guard Datasheet (431 kb)
Datasheet on the Guard Kit and Extended Guard for the PCNC 1100 mill
07/19/07 - Machine Arm Datasheet (529 kb)
Datasheet on the optional Machine Arm for PCNC mills.
PCNC 770 - Options - Machine Arm Stands and Coolant Kit Manuals
PCNC 770 - Options - Machine Arm Stands and Coolant Kit Datasheets
PCNC 770 - Options - Machine Arm Stands and Coolant Kit Technical Documents
PCNC 770 - Options - Machine Arm Stands and Coolant Kit Drawings
PCNC 770 - Options - Machine Arm Stands and Coolant Kit Service Bulletins
PCNC 770 - Options - Machine Arm Stands and Coolant Kit General Policies
