Personal CNC 770 Mill Installation Tools
About the Lifting Bar
The lifting bar is an accessory used for hoisting a PCNC mill, primarily for the purpose of placing the mill on a stand. When installed properly it provides a lift point directly over the center of gravity. The set includes bar and all necessary chains, shackles and attachment hardware. Detailed instructions are included with the set.
Common lift equipment such as engine hoists or chain hoists attached to overhead beams commonly have limitations in vertical lift capacity. The lifting bar provides a lift point as low as possible relative to the machine frame. This allows lifting the mill up on top of a stand despite low overhead clearance and the limited reach of an engine hoist. The kit includes locking hardware plate that properly distributes force in the T slot and ensures that the chain will not slip horizontally in the slot.
About the PCNC 770 Moving Kit
Exclusive to the PCNC 770, the patent-pending moving kit lets you disassemble your PCNC 770 into 3 subcomponents (column, base, and head) for easy relocation into small spaces like basement or garage workshops. The moving kit includes everything you need for to safely disassemble the PCNC 770 into manageable pieces without damaging any of its precision surfaces.
PCNC 770 - Installation Tools Documents
All PCNC 770 - Installation Tools Documents
07/07/11 - Assembly Instructions for the PCNC 770 Stand and Arm (1396 kb)
Assembly of the Tormach PCNC 770 Stand and the Tormach PCNC Machine Arm
07/03/07 - Lifting Bar Datasheet (509 kb)
Datasheet on the Tormach Lifting Bar used to move the PCNC mill.
PCNC 770 - Installation Tools Manuals
PCNC 770 - Installation Tools Datasheets
PCNC 770 - Installation Tools Technical Documents
PCNC 770 - Installation Tools Drawings
PCNC 770 - Installation Tools Service Bulletins
PCNC 770 - Installation Tools General Policies
