Tormach Closed for Memorial Day Holiday
Tormach will be closed Monday, May 27th (5-27-13) for the Memorial Day Holiday.
Orders received after 1:00pm(CST) on Friday, May 24th (5-24-13) will not be processed until Tuesday, May 28th (5-28-13).
Give the perfect gift to your machinist with a Tormach Gift Certificate.
CNC operations work best with one holder for each tool. An interchangeable set of tool holders, along with a means for off-line tool measurement, allows full utilization of the tool length compensation table in your CNC controller. The CNC set includes a total of 15 tool holders, a granite surface plate with integrated locating hole and dial height gauge. If your CNC machine supports a tool offset table but you’re not using it, then you’re not realizing the full benefit of CNC machining.
