Vectric CAM Software
About Vectric CAM Software
Vectric CAM products are affordable, innovative software solutions for your CNC machine. Vectric's products win high marks for usability. With easy-to-use interfaces and simple presentation, Vectric's CAM solutions are great choices for both beginning and experienced CAM users. Tormach is a Vectric reseller.
Cut2D
Simple to learn and simple to use, Cut 2D is a great way to get started with 2D and 2.5D CAM. Import DXF files from your CAD program or draw your own simple parts within the Cut2D interface and design profiling, pocketing, and drilling toolpaths. Tormach/ Mach3 postprocessor included.
Cut3D
The easiest way to get started with 3D CAM. Import 3D CAD models and design simple but effective roughing and finishing toolpaths to carve your part. Perfect for artistic machining, rapid prototyping, and engraving. Includes options for one, two, or four-sided machining. Tormach/ Mach3 postprocessor included.
VCarve Pro v6
Professional quality 2D and 2.5D CAM. VCarve Pro has advanced 2D and 2.5D toolpath design tools – Engraving, Nesting, Pocketing, Prism Machining, and more.
Aspire v3
A specialty CAM package for creating 3D relief models from many different digital sources. Perfect for sign making and architectural machining and CNC sculpting.
Photo VCarve
A Truly Unique Product, PhotoVCarve is a specialty CAM package that instantly converts photographs and images into high quality toolpaths that can be run on virtually all CNC routing and engraving machinesSoftware - Vectric CAM Documents
All Software - Vectric CAM Documents
A summary of the CAD/CAM process and a guide for making an informed purchasing decision with regards to CNC programming software.
Software - Vectric CAM Technical Documents
