PathPilot® Software Center
PathPilot® Issues & Feature Requests Tracking
TypeIssue #TitleStatusCreated
bug 1199 Mill - Probing: Probing buttons fail if axes softlimits are shortened via ADMIN SET_X_LIMIT or SET_Y_LIMIT open 2016-06-03
bug 1001 Mill/Lathe - File tab: Right click for cut/copy/paste is missing from new file interface. open 2015-08-04
bug 1011 Mill - Toolpath preview: Program extents not always displayed on first program load, sometimes you need to change the view to see them. open 2015-08-10
bug 999 Mill - 4th Axis: Max Velocity override does not affect A axis moves open 2015-08-01
bug 1100 Mill/Lathe - Metric Step Sizes: Change step sizes to 0.005, 0.010, 0.100, 1.000 open 2015-12-08
bug 1099 Mill/Lathe - Conversational: DROs should have only 3 decimal places of precision in G21 open 2015-12-08
bug 925 Mill/Lathe - G code interpreter: Block Delete not supported open 2015-05-26
bug 1151 Mill - M3: M3 S0 (spindle run with zero speed) results in machine waiting for at-speed indefinitely open 2016-03-11
bug 1323 Lathe - Reset: Can't bring machine out of reset if a limit switch is active open 2016-11-07
bug 1283 Lathe - Conversational ID Thread: Retract at driveline, not beyond, to prevent collision open 2016-09-26
bug 265 Mill/Lathe - Shutdown screen: Instruction to power off computer is hard to read on some computers open 2013-11-22
bug 839 Mill/Lathe - USBIO: User should get error message if board is enabled on settings screen but not connected open 2015-03-18
bug 866 Mill - Toolpath preview: G code with A axis moves is not always well rendered in tool path preview open 2015-04-06
bug 1125 Mill - Set Start Line: If machine is in G54, and set start line feature is used on a program in G55, and program is aborted half way through, DROs will read in G54 offsets open 2016-01-21
bug 1337 Mill - Probing: Find A Axis Center routine is off in Z by the value of the probe radius open 2016-12-08
enhancement 825 Mill/Lathe - Settings screen enhancement: Add M codes to the G codes cheat sheet open 2015-03-12
enhancement 804 Touchscreen - Popup lacks Capslock key to allow users to make capital letters via soft keyboard open 2015-03-03
enhancement 862 Mill - Conversational enhancement: Add angle wrt X axis to engraving tab open 2015-03-31
enhancement 1013 Mill/Lathe - Tool tips: add a "learning" mode setting that enables tool tips with descriptions of functions/buttons/dros open 2015-08-13
enhancement 988 Mill/Lathe - Touchscreen: Add ability to get right click menu from touch. open 2015-07-20
enhancement 997 Mill - Conversational: Face routine should accept Z start = Z end open 2015-08-01
enhancement 878 Mill/Lathe - Touchscreen enhancement: Make touch area for override sliders larger so they are easier to 'grab' with a finger open 2015-04-15
enhancement 815 Mill/Lathe - Touchscreen: Need soft keyboard for tool table entries open 2015-03-06
enhancement 1021 Mill/Lathe - USB IO board: Add buttons to control relay output state, switchable during G code execution. open 2015-08-25
enhancement 1028 Mill/Lathe: File Tab: Make hard drive window larger and hide USB window and buttons when no USB stick is plugged in open 2015-08-31
enhancement 1332 Mill/Lathe - MDI: Up arrow cycles backward through MDI history, add down arrow to move forward in history open 2016-11-22
Live Help Chat
Live Chat Software
