Learning Center
G-codes Machine Code Reference
- G-code Table
- G00 - Rapid Linear Motion
- G01 - Linear Motion at Feed Rate
- G02 and G03 - Arc at Feed Rate
- G04 - Dwell
- G10 - Coordinate System Data Tool and Work Offset Tables
- G12 and G13 - Clockwise / Counterclockwise Circular Pocket
- G15 and G16 - Exit and Enter Polar Mode
- G17, G18 and G19 - Plane Selection
- G20 and G21 - Length Units
- G28 and G30 - Return to Home
- G28.1 - Reference Axes
- G31 - Straight Probe
- G40, G41 and G42 - Cutter Radius Compensation
- G43, G44 and G49 - Tool Length Offsets
- G50 and G51 - Scale Factors
- G52 - Temporary Coordinate System Offset
- G53 - Move in Absolute Coordinates
- G54 to G59 and G59 P~ - Select Work Offset Coordinate System
- G61 and G64 - Set Path Control Mode
- G68 and G69 - Coordinate System Rotation
- G73 - Canned Cycle - High Speed Peck Drill
- G80 - Cancel Modal Motion
- G81 to G89 - Canned Cycles
- G90 and G91 - Distance Mode
- G92, G92.1, G92.2 and G92.3 - G92 Offsets
- G93, G94 and G95 - Set Path Control Mode
- G98 and G99 - Canned Cycle Return Level
Socialize
