Haimer® Zero Master
Zero Master 3D Sensors
Haimer Zero Master 3D sensors are professional quality precision German-made universal 3D sensors for precise and fast indication of edges and surfaces (X, Y or Z axis). These 3D indicators are the ultimate edge finding tool and a perfect fit for Tormach Personal CNC mills and any other CNC or manual milling machine.
Considered the ultimate in 3D edge and surface detection, with nominal measuring accuracy of +/- 0.01 mm, Haimer Zero Master 3D sensors (or 3D tasters, as referred to in Germany) are available from Tormach in both digital and analog dial versions.
Haimer Zero Master Digital
The Haimer Zero Master Digital has a large easy to read display, measuring in increments of 0.01 mm, in a splash-proof and dust-proof housing with a long battery life. The shaft diameter is 0.375”. Details >
Haimer Zero Master Analog
The Haimer Zero Master Analog provides the same quality and precision in a small easy to use analog version, with a shaft diameter of 10 mm (also fits ISO 30 and small HSK spindles) Details >
Tormach also offers low-profile TTS holders and replacement tips for both the Zero Master Digital and Zero Master Analog 3D sensors. Purchase Haimer Zero Master 3D sensors individually, or in a set that includes the sensor and TTS holder. Details >
About Haimer GmbH
Haimer is a premier manufacturer of tool holding and 3D sensor products. Haimer was founded over 30 years ago as a family-owned precision manufacturer near Munich, Germany. At Haimer, all products are made in house in Germany. Each year, 10% of revenue goes back into the research and development of our product offering, assuring that Haimer will provide you with the most innovative machining center tooling solutions in the world. Haimer’s motto, “Quality Wins”, and they are dedicated to offering our top-level quality product at a fair price to the end-user.
Tormach is a proud reseller of Haimer 3D Sensor products, including the Zero Master family of 3D tasters (German for calipers)
TTS - Measurement Tools Documents
All TTS - Measurement Tools Documents
Tormach Tooling System Catalog
TTS Electronics Datasheet
Tormach Tooling System Introduction
TTS Tool Sets Datasheet
Manual for Tormach Tool Assistant™
TTS - Measurement Tools Manuals
TTS - Measurement Tools Datasheets
