BT30 Spindle Cartridge
About the BT30 Spindle Cartridge
A drop-in substitute for the factory standard R8 spindle included with the PCNC 1100 mill, suitable for use with most BT30 toolholders. Designed for use with drawbar; will not work with pull studs. Not compatible with Tormach Tooling System® ATC and some other accessories.
Not compatible with TTS toolholders. Not compatible with the PCNC 770.
Upgrades - BT30 Spindle Cartridge Documents
All Upgrades - BT30 Spindle Cartridge Documents
03/05/12 -
DS10110: Datasheet on PCNC Options
(553 kb)
Datasheet on PCNC Options: Spindle Load Meter, Automatic Oiler, and BT30 Spindle Cartridge
11/06/08 -
Spindle Cartridge Assembly Drawing
(93 kb)
Drawing of the PCNC 1100 Spindle Cartridge Assembly (PN 30305 & 30306).
Upgrades - BT30 Spindle Cartridge Datasheets
03/05/12 -
(553 kb)
Upgrades - BT30 Spindle Cartridge Drawings
11/06/08 -
(93 kb)
