The Speeder is Here!
July 21, 2010 by: Andy G.
Tormach Speeders will be available for sale this week on tormach.com. I interviewed Matt for a quick youtube clip on the Speeder basics.
Here are a few answers to some other questions we have received over that last few months.
Q: Can the Speeder do 30k RPM?
A: Yes, but realize there will be tradeoffs with belt, and most likely spindle bearing life. However, both belts and spindle cartridges are stocked individually as replacement parts. We’ve rated the speeder for continuous operation at 20k RPM.
Q: What is the exact pulley ratio?
A: 1:3.2. If you need to know RPMs exactly, the true test is an optical tachometer. You’ll have slight RPM losses from friction, etc. — so the best way is to measure what you really have is with the tach.
Q: Can I use Coolant?
A: Yes, but be aware of certain restrictions. The lower spindle is sealed against coolant using a labyrinth seal which means that spindle rotation is required for sealing action. Best practice is to turn coolant on only after the spindle is spinning and turn coolant off before the spindle is turned off. This should be a standard procedure with any high speed spindle. The upper sections, where the belt drive transmission exists, should not be exposed to coolant.
In the video, Matt mentions that we dynamically balance the ER16 collet nut, and that reminded me about something we did during the inital spindle balance calculations. We were interested in estimating how far the center of mass is offset from the centerline of the ER nut as result of the nut’s inherently imbalanced design. CNC Scanner made that really easy to figure out. Our estimate determined that the contribution to imbalance wasn’t insignificant. Based on that, we ended up getting a few nuts balanced for testing in the lab, and ultimately deciding to make balanced nuts standard with the product.
This is FANTASTIC! Congratulations to Tormach on this device. I have many customers who will be interested in this immediatly. (I of course will want one too!)
