TurboCAD/CAM
TurboCAD/CAM has TurboCAD at its core. This is a link to a description of the CAD program:
Extended TurboCAD Description
CAM Features in TurboCAD/CAM
Simplistic CAM programs will create G & M codes directly as you pick out paths or objects in a CAD drawing. It seems easy to make progress as you work, but going back and making changes can be difficult.
More advanced CAM programs, like TurboCAD/CAM, will generate conceptual operations that are essentially machine independent. While the resulting G & M codes might be displayed, the program is actually recording ideas, like "pocket this area," or "edge mill this contour." This is quite different than recording just the motions like "move X 3 inches." The result is that your work is much easier to edit, retaining the ability to modify properties of individual operations or even whole groups of operations. Now, this wouldn't be a software description without a feature list.
  • Operations arranged on Explorer® like tree structure.
  • Supports both mill and lathe operations.
  • Comprehensive tool library with editable entries, allows you to build your own tool table.
  • Large tool table stores tool operating preferences.
  • Cutting simulation in 3D.
  • Drawing and CAM are linked. If you modify the drawing after developing the CAM, the cutting operations are automatically updated.
  • Automatically generates 3D models with photorealistic rendering. Simple 2D drawings are all that are needed, but the 3D models are automatically derived as you specify the CAM operations.
  • Automatic lead in and lead out.
  • Dynamic tool path copy.
  • Supports tapping head.
  • CAM setup wizard.
  • Change operation's depth, feed, or speed with one click.
  • Load factor compensation for machine and tool
  • Reorder by tool, operation, or part.
  • Controller support for Tormach, Fadal, Fanuc, and Haas
TurboCAD/CAM Training and Support
The program comes with a good tutorial, usually enough to get you started. For a more detailed understanding we suggest purchasing TurboCAD/CAM movie CD. This is a series of short movies, each one training on a different set of software features.
Tormach can only offer limited support on TurboCAD/CAM. Extensive training and support is offered by CadCourse.com. The people at CadCourse are closely involved with the publisher and have excellent knowledge of the product.
Home  |  Company  |  Products  |  Sales  |  Resources  |  Help & Support
