About the Digitizing Probe
Tormach offers an electronic Digitizing Probe (PN 30668), shown to the right, which enables faster setup of jobs on the machine. The probe is used to set the work offset values corresponding to the position of the work on the table or in the vise. It has a standard TTS (¾") shank and is best used in the ¾" R8 collet (PN 30146). The standard probe tip is 0.1575" in diameter (4 mm). The probe cable has a male 5 pin DIN connector. This connector will join to the auxiliary socket provided on the PCNC 1100 operators control panel. The Tormach Digitizing Probe also comes with a sturdy storage case.
About the Tool Setter
The Tormach Tool Setter (PN 30669), is typically used to measure and set tool lengths and Z-axis work offsets. When contacted by a tool it works with the machine control software to record position. The tool setter enables fast and accurate measurement of tools and setup of jobs. It also has the advantage of setting work offsets with no risk of chipping the edges of high performance carbide mills. The tool setter cable has a male 5 pin DIN connector. This connector will join to the auxiliary socket provided on the PCNC 1100 operators control panel. The Tormach Tool Setter also comes with a sturdy storage case.
