About the Machine Arm
Tormach's
Machine Arm (photo on left) is a
great addition to your PCNC 1100.
It can be mounted directly on the
machine column. It has a rigid support
with a machined cast iron support
bracket, two sturdy steel extension
arms, and a center pivot. It is
fully adjustable and easy to install.
Any LCD with a standard VESA 75
mm or 100 mm mount can be used.
Every machine comes with the column drilled and tapped to fit our cast iron bracket. The supporting arms are machined to allow routing the cables inside the arms.
The Tool Tray (photo on right) is used in conjunction with the Machine Arm (sold separately) and used to hold up to 20 tools.
Please note, LCD displays and keyboards normally need extension cables when used with a keyboard arm. Our video extension is PN 30280, the USB extension is PN 30279.
