| Most people who see a stand made using this method are surprised to learn that it's a wooden construction. When properly made, the only way to tell is to look inside, or note that the surface is warm to the touch.
The slots on the bottom are for a pallet jack or lift truck.
Drawings and more detailed notes are available in our document library, in the file
TD_DIY_StandDrawings.zip. The stand was designed for the preproduction model of the PCNC 1100 and some dimensions have changed. It will be worthwhile to compare the footprint to the current PCNC 1100 footprint, file
PCNC base dimensions.pdf in the document library.
We would appreciate any design notes and photos for alternative solutions.
Whether you build a wooden stand, a welded steel stand, or park it on a granite pedestal, always make certain that your setup is safe an secure. The safety of installation, configuration, and operation of any machine remains the responsibility of the machine owner.
