4th Axis Kit Information
The
4th axis kit extends your machining
capability to include rotation of
the work piece. This a fully integrated
axis, allowing simultaneous and
coordinated motion with all other
axes. Whether you are cutting timing
screws, cable winding drums, turbine
impellers, or simply engraving on
cylinders, our 4th axis options
are just the ticket. Choose from
the 8" or 6" kits.A 4th axis kit addition is comprised of a motorized rotary table, plus integration kit. The integration kit includes the axis driver, wiring, and connection port. Installation instructions are included in the PCNC 1100 manual. The rotary table itself and each of the table accessories come with all necessary mounting hardware. The rotary table and tailstock have 5/8" slot keys for alignment to the mill table.
The chucks and the 5C adaptor each come with a mounting adaptor plate, T-nuts, and all hardware necessary for easy mounting. The rotary tables are painted to match the machine color. 8" tables have the same NEMA 34 motor as the X and Y axis drives on the milling machine. The 6" table has a smaller NEMA 23 motor.
