6" Tables and Accessories
Our Motorized Rotary Tables are designed and built for everyday machining operations. These tables are popular with machine builders, manufacturing engineers, and OEMs looking for affordable rotary precision. These tables operate at 1800 degrees per minute (approx. 5 RPM) and utilize hydrodynamic bearing surfaces and manually operated table locks.
We offer standalone motorized tables in several sizes and configurations. We also offer each table size integrated 4th axis kits for our PCNC mills. These kits include not only the motorized table, but electronic driver modules and wiring harnesses. Features include:
- Direct Drive Transmission. Our tables utilize a direct drive shaft coupling instead of the belt drive design found on other motorized turntables. This approach eliminates side loading on the worm screw bearing.
- Vertical or Horizontal Operation. Each table features ground mounting surfaces to allow mounting two ways, either vertically as a Rotary A-axis or horizontally as a C-axis.
- Sealed Motor. The drive motor is specifically engineered for operation in a metal cutting environment. The motor mount has a sealing O-ring at the face and is completely sealed against cutting fluids, chips, and dust.
- Adjustable Backlash. The engagement of the worm gear with respect to the ring gear can be adjusted to minimize backlash and compensate for wear over the tables lifetime.
- Low Profile Clamp Kit. Convenient Clamps allow for quick and easy mounting without need for unwieldy strap clamps.
Chucks and Accessories
We also offer tailstocks and a large assortment of compatible chucks and collet closers suitable for general purpose rotary workholding. Options include:
3 jaw chucks: 3 jaw chucks are easy to use and self-centering. They can be used to hold round or hex stock.
4 jaw chucks: While 4 jaw chucks aren’t self-centering, they offer versatility in that they can be used to hold square/rectangular stock and can be used for off-center work.
2 Jaw chucks: A self centering two jaw chuck is a convenient option for subtractive rapid prototyping
5C Collet Holders and Closers: Collets are a great choice for holding slender round stock and will generally have less runout than 3 jaw chucks. We carry options for both the common 5C system.
MT3 Collet and Drawbolt: The Center hole of the 8” rotary table has a #3 Morse taper (MT3). This collet and drawbolt allows mounting Tormach Tooling System® (TTS) holders on the rotary table, allowing TTS to hold a workpiece instead of a tool. Ideal for small diameter stock.
| Specifications | 6" Motorized Rotary Table |
| Table Diameter | 160 mm |
| Taper of Center Hole | 2MT |
| Width of T-slot | 10 mm |
| Adjacent Angle of T-slot | 90° |
| Width of Locating Key | 5/8" |
| Worm Ratio | 90:1 |
| Graduation / Vernier | 1° / 10" |
| Angle per Full Step | 0.02° |
| Motor Steps | 200/rev |
| Motor Winding | 2 phase |
| Motor Inductance | 5.73 mH |
| Motor Resistance | 1.34Ω |
| Motor Phase Current | 2.8 A |
| Motor Holding Torque | 1.9 Nm |
| Motor Mount | NEMA 23 |
| Motor Shaft | 1/4" |
| Cable | 10' high flex |
| Shipping Weight | 70 lbs |
Rotary and 4th Axis Documents
All Rotary and 4th Axis Documents
Datasheet for Tormach Rotary Products and Accessories
Operator's Manual for Tormach 4th Axis and Rotary Products including the 6 Inch Tilting Rotary Table, 8 Inch Tilting Rotary Table, 6 Inch Rotary Table and the 8 Inch Rotary Table.
Tormach Motorized Tilting Rotary Table QC
Quality Certification for the 8" Motorized Table.
Quality Certification for the 6" Motorized Table.
Rotary and 4th Axis Manuals
Rotary and 4th Axis Datasheets
Rotary and 4th Axis Technical Documents
