6" Tables and Accessories
Our Motorized Rotary Tables are designed and built for everyday machining operations. These tables are popular with machine builders, manufacturing engineers, and OEMs looking for affordable rotary precision.  These tables operate at 1800 degrees per minute (approx. 5 RPM) and utilize hydrodynamic bearing surfaces and manually operated table locks.
We offer standalone motorized tables in several sizes and configurations.  We also offer each table size integrated 4th axis kits for our PCNC mills.  These kits include not only the motorized table, but electronic driver modules and wiring harnesses.  Features include:
  • Direct Drive Transmission. Our tables utilize a direct drive shaft coupling instead of the belt drive design found on other motorized turntables. This approach eliminates side loading on the worm screw bearing.
  • Vertical or Horizontal Operation. Each table features ground mounting surfaces to allow mounting two ways, either vertically as a Rotary A-axis or horizontally as a C-axis.
  • Sealed Motor. The drive motor is specifically engineered for operation in a metal cutting environment. The motor mount has a sealing O-ring at the face and is completely sealed against cutting fluids, chips, and dust.
  • Adjustable Backlash. The engagement of the worm gear with respect to the  ring gear can be adjusted to minimize backlash and compensate for wear over the tables lifetime.
  • Low Profile Clamp Kit. Convenient Clamps allow for quick and easy mounting without need for unwieldy strap clamps.
Chucks and Accessories
We also offer tailstocks and a large assortment of compatible chucks and collet closers suitable for general purpose rotary workholding. Options include:
3 jaw chucks: 3 jaw chucks are easy to use and self-centering. They can be used to hold round or hex stock.
4 jaw chucks: While 4 jaw chucks aren’t self-centering, they offer versatility in that they can be used to hold square/rectangular stock and can be used for off-center work.
2 Jaw chucks: A self centering two jaw chuck is a convenient option for subtractive rapid prototyping
5C Collet Holders and Closers: Collets are a great choice for holding slender round stock and will generally have less runout than 3 jaw chucks. We carry options for both the common 5C system.
MT3 Collet and Drawbolt: The Center hole of the 8” rotary table has a #3 Morse taper (MT3). This collet and drawbolt allows mounting Tormach Tooling System® (TTS) holders on the rotary table, allowing TTS to hold a workpiece instead of a tool. Ideal for small diameter stock.
Specifications 6" Motorized Rotary Table
Table Diameter 160 mm
Taper of Center Hole 2MT
Width of T-slot 10 mm
Adjacent Angle of T-slot 90°
Width of Locating Key 5/8"
Worm Ratio 90:1
Graduation / Vernier 1° / 10"
Angle per Full Step 0.02°
Motor Steps 200/rev
Motor Winding 2 phase
Motor Inductance 5.73 mH
Motor Resistance 1.34Ω
Motor Phase Current 2.8 A
Motor Holding Torque 1.9 Nm
Motor Mount NEMA 23
Motor Shaft 1/4"
Cable 10' high flex
Shipping Weight 70 lbs
Rotary and 4th Axis Documents
All Rotary and 4th Axis Documents
09/18/14 - SM10299: Mounting Kit for Tombstone (56 kb)
Zip file includes:
34726_Mounting_Kit_for_Tombstone.IGS
34726_Mounting_Kit_for_Tombstone.STEP
09/18/14 - SM10298: 8 Inch Tombstone (183 kb)
Zip file includes:
33146_8_Inch_Tombstone.IGS
33146_8_Inch_Tombstone.STEP
08/13/14 - SM10275: 8 Inch Tilting Rotary Table Horizontal Solid Models (1150 kb)
Zip file includes:
31848_8_Inch_Tilting_Rotary_Table_Horiz.IGS
31848_8_Inch_Tilting_Rotary_Table_Horiz.STEP
08/13/14 - SM10274: 8 Inch Titling Rotary Table Solid Models (1173 kb)
Zip file includes:
31848_8_Inch_Titling_Rotary_Table.IGS
31848_8_Inch_Titling_Rotary_Table.STEP
07/11/14 - SM10277: 6 Inch Super Spacer w Chuck Solid Models (1014 kb)
Zip file includes:
34123_6_Inch_Super_Spacer_w_Chuck.IGS
34123_6_Inch_Super_Spacer_w_Chuck.STEP
07/11/14 - SM10276: 6 Inch Super Spacer w Faceplate Solid Models (1014 kb)
Zip file includes:
34123_6_Inch_Super_Space_w_Faceplate.IGS
34123_6_Inch_Super_Space_w_Faceplate.STEP
07/02/14 - SM10270: 8 Inch Super Spacer w Faceplate Solid Models (1220 kb)
Zip file includes:
34122_8_Inch_Super_Spacer_w_Faceplate.IGS
34122_8_Inch_Super_Spacer_w_Faceplate.STEP
07/02/14 - SM10269: 8 Inch Super Spacer w Chuck Solid Models (849 kb)
Zip file includes:
34122_8_Inch_Super_Spacer_w_Chuck.IGS
34122_8_Inch_Super_Spacer_w_Chuck.STEP
02/06/14 - UM10069: Tormach 4th Axis and Rotary Products Operator's Manual (1768 kb)
Operator's Manual for Tormach 4th Axis and Rotary Products including the 6 Inch Tilting Rotary Table, 8 Inch Tilting Rotary Table, 6 Inch Rotary Table and the 8 Inch Rotary Table.
12/02/13 - SM10197: 6 Inch Tilting Table Solid Models (429 kb)
Zip file includes:
31847_6_Inch_Tilting_Table.IGS
31847_6_Inch_Tilting_Table.STEP
12/02/13 - SM10196: 6 Inch Tilting Table Verticle Solid Models (433 kb)
Zip file includes:
31847_6_Inch_Tilting_Table_Verticle.IGS
31847_6_Inch_Tilting_Table_Verticle.STEP
12/02/13 - SM10195: 4 Jaw 6 Inch Chuck Solid Models (930 kb)
Zip file includes:
31721_4_Jaw_6_Inch_Chuck.IGS
31721_4_Jaw_6_Inch_Chuck.STEP
12/02/13 - SM10194: 3 Jaw 6 Inch Chuck Solid Models (879 kb)
Zip file includes:
30292_3_Jaw_6_Inch_Chuck.IGS
30292_3_Jaw_6_Inch_Chuck.STEP
12/02/13 - SM10193: 3 Jaw 8 Inch Chuck Solid Models (125 kb)
Zip file includes:
30291_3_Jaw_8_Inch_Chuck.IGS
30291_3_Jaw_8_Inch_Chuck.STEP
12/02/13 - SM10192: Tailstock Assembly Solid Models (896 kb)
Zip file includes:
30272_Tailstock_Assembly.IGS
30272_Tailstock_Assembly.STEP
12/02/13 - SM10191: Tall Tailstock Solid Models (852 kb)
Zip file includes:
30197_Tall_Tailstock.IGS
30197_Tall_Tailstock.STEP
12/02/13 - SM10190: 8 Inch Rotary Table Solid Models (694 kb)
Zip file includes:
30194_8_Inch_Rotary_Table.IGS
30194_8_Inch_Rotary_Table.STEP
07/13/12 - TD10141: 4th Axis Homing Kit Installation (300 kb)
Installation procedure of the Tormach Fourth Axis Homing Kit
05/03/12 - DS10041: Rotary Products and Accessories Datasheet (736 kb)
Datasheet for Tormach Rotary Products and Accessories
06/29/11 - Tormach Motorized Tilting Rotary Table QC (45 kb)
11/17/09 - 8" Motorized Table Quality Certification (31 kb)
Quality Certification for the 8" Motorized Table.
11/17/09 - 6" Motorized Table Quality Certification (31 kb)
Quality Certification for the 6" Motorized Table.
Rotary and 4th Axis Manuals
Rotary and 4th Axis Datasheets
Rotary and 4th Axis Technical Documents
Rotary and 4th Axis Drawings
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Zip file includes:
Rotary and 4th Axis Service Bulletins
Rotary and 4th Axis General Policies
