Duality Lathe 4th Axis
About Duality Lathe 4th Axis
The Duality Lathe™ 4th Axis attachment allows you to convert your Duality Lathe headstock in to a 4th-axis, allowing you to cut keyways, pockets, helixes, etc. on turned parts with a single setup. It shares the same electronic integration components as our other 4th axis products.
It utilizes a zero backlash harmonic drive to achieve a high gear reduction without the need for multi-stage planetary gear system. This provides ultimate utility, allowing it to share electronic integration with our conventional 4th-axis kit.
Kit includes motor and driver, wiring kit, and harmonic drive gears. The driver is not necessary if a conventional rotary 4th axis kit has already been installed.
PCNC Options - Duality Lathe Documents
All PCNC Options - Duality Lathe Documents
E-stop Installation for the Duality Lathe.
Mach3 (M3) is the current release of the operating software for the Tormach PCNC mill and Duality Lathe. It is based on a general purpose CNC control program known as Mach3. This document covers the current version of M3 designed to be used with the Duality Lathe when used in conjunction with the PCNC Mill. This software should not be confused with that which runs the PCNC 1100 Mill.
Datasheet on the Duality Lathe.
Manual for the Duality Lathe.
Design Analysis of the Duality Lathe.
PCNC Options - Duality Lathe Manuals
PCNC Options - Duality Lathe Datasheets
PCNC Options - Duality Lathe Technical Documents
